Author Topic: [IC]Outemu Butterfly Silent Linear switch  (Read 4379 times)
Offline moyu.studio
« on: Fri, 09 August 2024, 05:30:23 »
Hello
This time we bring the Outemu Butterfly Silent Linear Switch
The butterfly switch was designed by XCJZ, a well-known switch collector in the East, in collaboration with jkdk, and manufactured by Outemu, a well-known switch manufacturer.
XCJZ (Lucy Switch Designer) has a deep accumulation in switch design. This time, together with Outemu, we have debugged multiple times to create this butterfly silent switch.
309296-0
Butterfly switch Specifications:
- Silent Linear
- 42g spring(20mm)
- POM Lengthen stem+TPU Soft Plasti
- Hardened polycarbonate top housing
- Hardened polycarbonate bottom housing
- 5 pin
- 3.7mm Travel
- Actuation force: 37±5gf
- Initial force: 25gf Min
- Pressure point force: 42gf Max
- Made by Outemu
- lubrication
- Designed by XCJZ×JKDK
309298-1
309300-2
Stem TPU Soft Plasti and transparent semi fluid grease lubrication
309302-3
The bottom is made of hardened polycarbonate and features a 20MM length 42g silent single ended extended spring,Similarly, there is semi fluid grease lubrication at the bottom of the spring
309304-4
The top is made of hardened polycarbonate material,And use Outemu light guide top mold
309306-5
PC material umbrella shaped frosted semi transparent light guide block
309308-6
The butterfly shaft is a standard silent linear switch with an extended spring and 3.7mm silent travel,Silent noise reduction.
Using butterfly color scheme, make every strike of yours fly like a butterfly
To ensure the broadest reach for the switches, I will be collaborating with many vendors worldwide. This ensures that as many people can purchase this switch at the lowest possible shipping.
In order to enable more people to quickly obtain the switch without waiting for a long time, we will use inventory sales. As long as we confirm the vendor list, we can transport it to the local area.
So this is a fast and cost-effective silent switch, I hope you like it
309310-7
309312-8
Sales method: Inventory sales
Price:0.3$/PCS(Adjustments will be made according to the region)
« Last Edit: Wed, 04 September 2024, 01:33:50 by moyu.studio »
Offline Keebzncables
Re: [IC]Outemu Butterfly Silent Linear switch
« Reply #1 on: Fri, 16 August 2024, 03:07:49 »
How does this compare to XCJZ Lucy and LICHICX silencing mechanism?
Offline moyu.studio
« Reply #2 on: Fri, 16 August 2024, 07:33:48 »
Both are great
