Author Topic: [In Stock] INFI75 HI-FI Hot-swappable Wireless RGB Keyboard With LCD Screen  (Read 5779 times)
Offline john08099
  • Velocifire MK
  • * Moderator
    • Mechanical keyboards for typers
INFI 75
No need for modding to enjoy a Hi-Fi typing sound
Discord | Instagram | TikTok
Intro
Hello guys. Today, we are thrilled to introduce a keyboard designed and manufactured by Keyverse studio–INFI75-'KEEP OUT!' EDITION.
Gallery
Photos IRL
Typing Test
Description
The INFI75 is a triple-mode mechanical keyboard that provides a perfect typing sound with the right level of keystroke resonance.
The keyboard features modern gasket mounting that yields the perfect bounce while typing. It also features custom IXPE switch pads and an additional HI-FI pad that retains the right amount of dampening, resulting in a great-sounding keyboard with no unwanted ping or hollow impact.
Additionally, it has an LCD screen, a multi-functional knob, a versatile 75-percent layout, and even a metal weight to add a more substantial feel to the setup.
The keyboard provides three modes of connectivity, including wired, Bluetooth, and 2.4 Ghz making it extremely versatile in use.
Overall, the INFI75 is the ideal choice for individuals seeking a reliable and great-sounding prebuilt mechanical keyboard.
Highlights
1. Compact 75% TKL Layout
2. Original Designed High-Quality Doubleshot PBT Keycaps
3. Premium Qing Ji Mechanical Switches
4. Multi-Layered Sound-Shock Absorbing Design (Original “Hi-Fi” pad)
5. RGB Musical Rhythmic Backlight
6. Full-Key Hot-Swappable Sockets
7. Colorful Display LCD Screen
8. Finely-Tuned Satellite Stabilizers
9. Versatile Triple-Mode Connection(Bluetooth V5.0, USB Type-C, Wireless 2.4GHz)
10. Long-Lasting Battery Life
11. Unique “Plastic-Metal” Structure
Specifications
Case Material: Plastic
Layout: 75% (78 keys)
Switches: Qing Ji linear switches, Pre-lubed,
Keycaps: Doubleshot PBT, 1.5mm thickness
LCD Screen: 135240, Full-color display
Connectivity: Type-C, Bluetooth 5.0, 2.4 GHz
Wireless range: Maximum 10 m straight line distance (the distance may become shorter depending on the obstruction)
Bluetooth device name: INFI75 5.0
Bluetooth polling rate: 125 Hz
2.4G device name: 2.4G Wireless Keyboard
2.4G polling rate: 1000 Hz
Net weight: About 1.1kg
Battery capacity: 3750 mAh
Plate-mounted stabilizers
Aluminum weight
Review
Merkeebs
Lewis Toh
Maker Mods
Seungup KBD
MCZ Studio
Simulator Tech
If you want to see more reviews, please check them on our product page!
Price
109USD
Sale Format
In Stock
Purchase Now
Please feel free to ask us any questions about the keyboard below! :)
Welcome to join our Discord and follow our Instagram,TikTok for more discussion, latest update and questions! :)
« Last Edit: Wed, 15 January 2025, 01:24:50 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
