Author Topic: [IC] PBTFans Astraeus | Coming in-stock tomorrow, May 22!  (Read 73087 times)
Offline balance
« on: Wed, 21 August 2024, 17:04:51 »
IC Form
Discord Server
Hello all!
Today, I present you this set under a new manufacture, PBTFans Astraeus. It is inspired by a mythological god of stars and planets. Incorporating space cadet sublegends and some beautiful shades of purple, this set evokes the mystique and vastness of the cosmos.
If you want to posses the ability of the art of astrology, your keyboard needs the following kits.
The set will be available starting tomorrow, May 22!
Vendors
US: Divinikey
EU: Inputgear.de
UK: Mechmods
CA: Deskhero
Global: KBDFans
Renders(done by KBDFans)
Base Kit - 69$
Covers many layouts: 60%, 65%, 80%
Alphas Kit - 12$
Your typical alphas kit.
Novelties Kit - 12$
Shows the process of universe in making.
Numpad Kit - 10$
Your typical numpad kit.
Spacebar Kit - 10$
Enhances your keyboard.
International Kit - 20$
Your typical international kit.
Let us see some board renders.
IC Form
Discord Server
If you are interested, please fill the form above and join the server for more updates
Thank you for your attention!
« Last Edit: Thu, 21 May 2026, 13:06:37 by balance »
Offline balance
Re: [IC] GMK CYL Astraeus | Hold the art of astrological magic
« Reply #1 on: Wed, 21 August 2024, 17:08:27 »
Reserved
Offline IOVERCALLHISTIOCYTES
« Reply #2 on: Wed, 21 August 2024, 17:09:54 »
I can choose only one kit to purchase in your current IC form. Can you let me select more than one?
Offline AMZ
« Reply #3 on: Wed, 21 August 2024, 17:10:55 »
I like the colors! GWIC
Offline balance
« Reply #4 on: Wed, 21 August 2024, 17:12:52 »
Fixed! Sorry for this and thanks for pointing this out :thumb:
Offline EdgeOfInfinity
« Reply #5 on: Wed, 21 August 2024, 18:09:08 »
are the alphas WS2?
Offline konstantin
  • Formerly constexpr
« Reply #6 on: Wed, 21 August 2024, 18:24:49 »
I like the colors but I really don't get the sublegends. Space cadet symbols don't have anything to do with actual outer space.
« Reply #7 on: Wed, 21 August 2024, 22:14:06 »
Counterpoint: I like cadet and would be happy to buy lavender version
What physical color standards do you have? I don’t have dragon witch but can send you example keys of the others if you want.
Seems like 3 key 40s or 4 key, don’t know what that community likes, would be ok to add for base.
Offline Cringelord
  • Crack Connoisseur
« Reply #8 on: Thu, 22 August 2024, 01:20:23 »
2024 and we're still not posting color codes on ICs lol
Offline keepoto
  • HHKB top for TKL pls
« Reply #9 on: Thu, 22 August 2024, 04:32:41 »
as long as samples are posted i dont see a problem, most people dont have colour chips at home and the online colour codes are not exactly accurate
Offline konstantin
« Reply #10 on: Thu, 22 August 2024, 06:10:46 »
RE sublegends: Have you considered using astrological and alchemical symbols? This would require new molds to be made (unless you opt for UV printing), which would increase the overall cost, but I think it would work a lot better with the theme of the set.
I believe this is intentional. A couple of years back, during the period of peak GMK popularity, sets that did well in GB were being readily cloned by Chinese manufacturers and sold through sites like Taobao, AliExpress and eBay, sometimes months or years before the original sets even shipped, so designers stopped publicly disclosing color references in hopes of curtailing this issue. I'm not sure how much of a problem this is nowadays, but I suspect it may have had something to do with the designer deciding against posting color codes for this set.
are the alphas WS2?
Doesn't look like it. WS2 is strikingly, take-your-eyes-out white, whereas this is more of a pale lavender color.
« Last Edit: Thu, 22 August 2024, 06:45:13 by konstantin »
Offline balance
« Reply #11 on: Thu, 22 August 2024, 11:09:23 »
are the alphas WS2?
No, all the colors are from RAL Design.
Offline Vadurr
  • Valar Morghulis
« Reply #12 on: Thu, 22 August 2024, 12:05:33 »
Big fan of the set but not sub legends x_x
« Reply #13 on: Thu, 22 August 2024, 13:23:55 »
ok - so, not white. got it. can never trust monitors with these super light colors
Offline balance
« Reply #14 on: Fri, 23 August 2024, 02:19:03 »
Hello, as mentioned the set is made using RAL Design colors. I chose them from my RAL D2 Book which helps me to match the colors as accurate as possible.
This is up to the designer's choice if they want to post the colors or not. When it comes to me, when you post your colors on the IC, your design might get stolen by different manufactures and can be sold at a lower price with a lower quality(as mentioned by konstantin). This case happened to me with my first ever ever set, GMK Blossom , my only set which had the colors posted on the IC.
« Last Edit: Fri, 23 August 2024, 04:32:06 by balance »
Offline bibione
« Reply #15 on: Sat, 24 August 2024, 11:35:49 »
Any chance to add 1U spacebar to the spacebar kit?
Offline balance
« Reply #16 on: Sun, 25 August 2024, 16:23:03 »
are the alphas WS2?
I understand your sublegend concern. So, while it doesn't have a direct link to outer space, its name and design can evoke a sense of futuristic, advanced technology that might be associated with space exploration. I would gladly change the sublegends, the problem is with the price growth and it is very essential for me to provide a convenient cost for the customers.
Offline AMZ
« Reply #17 on: Sun, 25 August 2024, 23:01:37 »
Hopefully will be there a Latin alpha as a separate kit
Offline balance
Re: [IC] GMK CYL Astraeus | Kitting changes | Added a new kit
« Reply #18 on: Tue, 27 August 2024, 15:26:28 »
Hello everybody, here is the new kitting update!
- Added 40s support in the base kit and 2 caps for a full numpad.
- Added a Latin Alphas Kit
Offline AMZ
« Reply #19 on: Tue, 27 August 2024, 17:11:47 »
I'm in after adding Latin alphas  :thumb:
Offline balance
« Reply #20 on: Fri, 30 August 2024, 16:21:35 »
If there will be more requests, sure.
Offline balance
« Reply #21 on: Thu, 05 September 2024, 14:07:34 »
That's nice to hear!
Offline Blamby
« Reply #22 on: Sat, 28 September 2024, 06:41:15 »
definitely cop
Offline balance
« Reply #23 on: Thu, 10 October 2024, 14:16:18 »
Offline bibione
« Reply #24 on: Fri, 18 October 2024, 05:47:04 »
Spacebar kit is missing a 1U for 3/1/3 spacebar
Offline balance
« Reply #25 on: Sun, 27 October 2024, 09:20:10 »
Added :thumb:
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #26 on: Sun, 27 October 2024, 11:25:50 »
Could you change 3key 40s to icons like the rest of the set?  :-X
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #27 on: Sun, 27 October 2024, 17:09:04 »
Also, some of the row labels in the base kit are incorrect:
Offline balance
« Reply #28 on: Sat, 02 November 2024, 17:11:43 »
Done! Thanks for the observation.
Offline balance
« Reply #29 on: Mon, 11 November 2024, 16:01:40 »
Thanks! I have changed the row labels.
Offline OrinNYC
« Reply #30 on: Thu, 14 November 2024, 18:33:39 »
these colors are nice!
Offline balance
« Reply #31 on: Mon, 18 November 2024, 14:47:56 »
Offline balance
« Reply #32 on: Mon, 25 November 2024, 16:26:22 »
Hello, here is another kitting update!
-The base kit doesn't contain sublegends anymore.
-Cadet subs are included in a separate kit.
« Last Edit: Tue, 07 January 2025, 13:35:33 by balance »
Offline Kaisar
« Reply #33 on: Mon, 25 November 2024, 19:09:00 »
I love the colors of this set! Great with international kit!
However, I would change the color of the ISO Enter to purple/lavender in the base kit to make it stand out more like the ANSI Enter. Either change the color or add a purple/lavender one.
GLWIC!
« Last Edit: Mon, 25 November 2024, 19:16:32 by Kaisar »
Offline balance
« Reply #34 on: Sun, 01 December 2024, 15:43:38 »
GLWIC!
Thanks! I will see what I can do about this.
« Last Edit: Tue, 07 January 2025, 13:35:16 by balance »
Offline Scucka
« Reply #35 on: Mon, 16 December 2024, 10:12:46 »
Nice changes! :thumb:
Offline bibione
« Reply #36 on: Thu, 19 December 2024, 17:08:04 »
How do the samples compare with GMK amethyst? Would have been nice to have 1U of the same color of the spacebar, not the alpha
Offline balance
« Reply #37 on: Tue, 07 January 2025, 13:36:26 »
A small update!
-Added more alpha-colored spacebars in the Spacebar Kit.
Offline balance
Re: [IC] GMK CYL Astraeus | Vendor Announcement!
« Reply #38 on: Tue, 14 January 2025, 13:42:50 »
Vendor Update!
Hello everyone! I have added the list of vendors for GMK CYL Astraeus.
Offline Kaisar
« Reply #39 on: Thu, 16 January 2025, 08:38:44 »
GLWIC!
Don't know if this was possible or not :D Just saw GMK Hippo in GB doing this.
Offline balance
« Reply #40 on: Mon, 03 February 2025, 12:12:39 »
GLWIC!
Hello! Thank you for your suggestion! I have now made this change according to your request.
Offline balance
Re: [IC] GMK CYL Astraeus | Deskmats Added!
« Reply #41 on: Sun, 16 February 2025, 13:31:47 »
New Update!
- Added 2 deskmat designs
- Added 2 renders of TGR JANE with GMK Astraeus on the Astromat!
Offline AMZ
« Reply #42 on: Mon, 17 February 2025, 14:07:24 »
I liked Astromat
Offline balance
« Reply #43 on: Tue, 25 February 2025, 14:12:28 »
Offline sagemintblue
« Reply #44 on: Fri, 28 February 2025, 00:00:53 »
I had the same thought. Consider including Amethyst in your color comparison. I love your choice here of the light purple for alpha base color.
Offline balance
« Reply #45 on: Tue, 04 March 2025, 16:49:00 »
Hello! Here is the comparison:
Offline balance
Re: [IC] GMK CYL Astraeus | CA Vendor Added!
« Reply #46 on: Mon, 17 March 2025, 16:57:12 »
CA vendor added!
Offline balance
Re: [IC] GMK CYL Astraeus | List of vendors updated!
« Reply #47 on: Fri, 28 March 2025, 18:54:05 »
SG and TH vendor added and now the vendor list is complete!
Offline balance
Re: [IC] GMK CYL Astraeus | First Metal Keycap Collab!
« Reply #48 on: Mon, 07 April 2025, 11:56:44 »
Posted the first metal keycap collaboration with the price of it!
Offline JackQn
« Reply #49 on: Mon, 07 April 2025, 19:37:29 »
Glad to hear that. :thumb: :thumb:
