Author Topic: Can anyone suggest a mouse that has light buttons  (Read 3953 times)
Offline ichirichi
« on: Tue, 26 October 2010, 08:22:12 »
Hi,
Anyone know of a mouse that is relatively cheap, buttons that doesn't need alot of force to press on to, and if possible, high dpi ?  Doesn't need alot of buttons, its mainly for work!  I use a Logitech MX518 at work, and find that it needs a lot more force compared to my Raza Naga at home...  I don't want to buy another Naga, 'cos its not the cheapest of mice and also if there mice that need less force to click then that would be awesome!
Thank you !
« Last Edit: Tue, 26 October 2010, 08:27:30 by ichirichi »
Offline woebtz
    • http://www.headcasegames.com
« Reply #1 on: Tue, 26 October 2010, 16:07:46 »
Are there any non-CST joystick pushbutton hacks for mice like ripster's?
It'd be cool to have cherry brown or Sanwa mice buttons on my trackpoint...
Filco Majestouch Tenkeyless CB, Apple Wired Keyboard, MS Comfort Curve 2000, Belkin n52te,
RollerMouse Pro, Ergonomic Touchpad, Magic Trackpad, Kensington Expert, Orbit Trackball w/ Scroll, IBM Scrollpoint III, Zalman FPSGun, Monster Gecko PistolMouse, Logitech TrackMan Wheel, Marble & First Pilot
[/COLOR]
Offline J888www
« Reply #2 on: Tue, 26 October 2010, 16:26:22 »
Logitech M310.
Very light click, very inexpensive, very good tracking, very much to my liking. Only 3 butttons & 1 AA battery, also comes in many colours & patterns. The demure click sound is so delightful that I often click for the sake of hearing the sound.
Purchased from US Seller on eBay for £24 all inclusive. Can also be purchased in UK from PC World at a higher price.
« Last Edit: Tue, 26 October 2010, 16:38:22 by J888www »
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline ichirichi
« Reply #3 on: Tue, 26 October 2010, 16:58:44 »
你好
Thanks man!
Offline hoggy
  • * Ergonomics Moderator
« Reply #4 on: Tue, 26 October 2010, 17:01:31 »
You could use autohotkey to reassign the caps lock key for left click.  Takes all the pressure off your normal click finger.
Offline J888www
« Reply #5 on: Tue, 26 October 2010, 17:03:26 »
Quote from: ichirichi;239115
你好
Thanks man!
Lol, 你好 translates "You Well".
My name is Monkey, great sage = to heaven.
« Last Edit: Tue, 26 October 2010, 17:14:31 by J888www »
Offline manfaux
« Reply #6 on: Tue, 26 October 2010, 23:48:00 »
kinzu has a really light click feel and a short actuation distance. Very basic mouse and sufficient dpi.
check out my listing :)
Offline tonyklo
« Reply #7 on: Wed, 27 October 2010, 20:17:46 »
I like Zowie EC-1 or EC-2 great tracking on any pads.
Pretty popular among FPS gamers : )
