Author Topic: [GB] Keykobo Verdigris | CANCELED  (Read 7167 times)
Offline Zetina
  • Big bird
    • Instagram
« on: Mon, 02 September 2024, 18:21:34 »
KeyKobo Verdigris
9 of September to 9 of October
Q2 2025
A Keycap set inspired by the Verdigris pigment developed by copper statues through oxidation.
Kits
Renders
Haus by Hand Engineering
Kaze by NRD Designs
910 by TGR
Phidias by Brunosan
Ryu Ergo by Geon
F1-8X 722 by Geon
Deskmat
900mm x 400mm x 4mm size, Rough surface, rubber bottom
By Roksow
Color sample
Vendors
US: Clickclack
CA: Unikeys
EU: Keygem
UK: Prototypist
SEA: iLumkb
KR: Geon*
OCE: Switchkeys
TW: PNKeyboard**
VT: MOKB
TH: Aiglaston
CN: Zfrontier
Geon's units will be sold in-stock after the groupbuy*
PNKeyboard sets will be sold via google form, join their discord server if interested in buying from them**
Pricing
  • Base kit: $93
  • Novelties: $55
  • Numpad: $19
  • Add-on $25
  • Deskmat $25
This pricing is only for the US region and during the GB period, other regions can vary
Special thanks to:
  • Stelladoscope for the amazing work on the novelties.
  • To all the guys on the KatanaKaji discord :-*.
  • Roksow for the amazing deskmat
If you are interested in being a vendor or doing a collab for the set you can reach out to me on discord as zetina.kb
You can also follow me on Instagram for more updates or join the Room 181 discord
If you want to support this project, consider adding the signature below to your profile:
Code: [Select]
[url=https://geekhack.org/index.php?topic=123110.0][img width=304 height=120]https://i.imgur.com/UTLJJKz.jpg[/img][/url]
« Last Edit: Thu, 31 October 2024, 21:18:18 by Zetina »
Instagram: @zetina.kb
Offline dvorcol
  • Discord: dvorcol_5071
Re: [GB] Keykobo Verdigris | Sept 9 - October 9
« Reply #1 on: Sat, 26 October 2024, 13:07:23 »
Offline Zetina
  • Big bird
    • Instagram
« Reply #2 on: Sat, 26 October 2024, 13:13:22 »
As you can see from Dvorcol's graph the GB for the set has been canceled, thanks to everyone who supported the GB
