Author Topic: Womier M68 HE - Cheap Hall Effect Keyboard  (Read 7736 times)
Offline Jū
    • Website
« on: Tue, 03 September 2024, 08:59:37 »
This is my first Hall Effect keyboard.
I'm not a gamer, so I can't take advantage of the benefits of this technology.
In my opinion, it would need a new lubrication of the switches; the factory lube is not uniform, and the sound of the springs is a bit noisy.
The case is similar to the GMK67, but the typing feel is halfway between a mechanical and a membrane keyboard.
The software is very complete. It allows you to remap both layers of keys, but on the second layer there are some restricted keys.
The actuation point and the rapid trigger can be configured for one or several keys at a time in a range that goes from 0.3mm to 4.0mm.
At the moment, it does not allow you to configure null binds. Maybe in a future software update they will include it.
I liked the advanced keys mode that allows Tap-mod, continuous trigger, and dynamic keystrokes.
Overall, for the price, it's not bad.
