Author Topic: Lucky65 - Your $80-ish ALU Mechanical Keyboard with a Dash of Luck!  (Read 5904 times)
Offline john08099
  • Velocifire MK
  • * Moderator
    • Mechanical keyboards for typers
« on: Mon, 09 September 2024, 19:42:59 »
Lucky 65
Designed by Weikav
Discord | Instagram | TikTok
Intro
Setting a new standard for affordability and quality in the world of mechanical keyboards, the Lucky65 is here to redefine your typing experience without breaking the bank.
With its sleek design, innovative features, and unbeatable price point, the Lucky65 embodies the perfect balance of performance and value. Whether you're a seasoned enthusiast or new to the world of mechanical keyboards, the Lucky65 promises to deliver an exceptional typing experience that will elevate your productivity and enjoyment.
Join us as we embark on this exciting journey with the Lucky65, the new budget mechanical keyboards for 2024!🍀
Gallery
Highlights
1. Compact Design: At just 65%, Lucky65 offers maximum functionality in a minimal footprint, optimizing your workspace without sacrificing performance.
2. Premium Build: Crafted with 6063 Aluminium material, Lucky65 boasts durability and longevity, ensuring it stands the test of time. Its smooth and matte finish lends an air of elegance, while subtle branding, including the distinctive four-leaf clover logo, emphasizes the theme and adds a touch of refinement without overpowering the overall design.
3. Customizable: With hot-swappable switches and fully programmable keys, Lucky65 empowers you to personalize your typing experience to match your unique style and preferences.
4. Dynamic Lighting: Illuminate your workspace with vibrant RGB backlighting, customizable to suit your mood or environment.
5. Effortless Connectivity: Lucky65 features versatile connectivity options, including wired and wireless modes, enabling seamless integration with any setup.
6. Highly Personalized : The exclusive Lucky65 personalized keyboard customization software provided by the factory can not only set the lighting mode but also freely change the keys, increasing the diversity of use and making the keyboard more in line with your personal needs.
7. Precisely adjusted stabilizers: After multiple precision calibrations, XinMeng stabs have reached the industry’s top level in terms of stability and typing feel, allowing you to enjoy an unprecedented typing experience during the typing process.
8. Hidden switch: The hidden switch does not affect the appearance of the keyboard, and it brings a more attractive user experience. It is under the TAB, you can switch to wired mode by using the switch or pressing FN+TAB.
9. Long-lasting battery life: The Lucky65 offers a 3500mAh battery, delivering up to 2-3 weeks of usage without RGB. Long battery life ensures uninterrupted work and entertainment, allowing you to stay productive and stay connected wirelessly for longer, without the need for frequent charging. What’s more, it allows you to charge and use at the same time in wired mode.
Specifications
Connectivity: Wired, 2.4G, BT5.0
Material: 6063 Aluminum
Surfacing: 150 Mesh Anodized (Carmine, Silver, Black, Navy Blue, Violet) ; Electrophoresis (Wave Blue, Milky White)
Weight: Gold Anodized Aluminium Weight
PCB:1.2mm Thickness ; ANSI Support or ISO Support ; Split space Support(Need additional plate) ; With Flex Cuts ; Plate Mounted Stabs Compatible
Net Weight: 1.2KG
Size: 326mm * 115mm * 33mm
Plate: 1.5mm ; PC material ; Support ANSI
Front Height: 20.5mm
Compatible System: Windows XP, Win7, Win8, Win10, macOS
Stabs: XinMeng V2 plate mount stabs ; Factory Lubed
Rolling rate: 1000Hz (wired & 2.4G) ; 125Hz (BlueTooth)
Battery: 3750mAh
South-facing RGB
Sound Test
Popular Review
Lewis Toh
Merkeebs
Seungup KBD
Keebored
Keebdude
Samuel Tan
Edwardtanujayaa
If you want to see more reviews, please check them on our product page!
Price
64.99USD
Sale Format
In Stock (Only carmine left now)
Purchase Now
Please feel free to ask us any questions about the keyboard below! :)
Welcome to join our Discord and follow our Instagram,TikTok for more discussion, latest update and questions! :)
« Last Edit: Fri, 11 October 2024, 02:40:03 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline john08099
  • Velocifire MK
  • * Moderator
Re: Lucky65 - Your $80-ish ALU Mechanical Keyboard with a Dash of Luck!
« Reply #1 on: Fri, 11 October 2024, 02:42:03 »
Don't miss out the sale!
Lucky65 Clearance sale price: 64.99USD(Original price 84.99USD)
Only 3 carmine color in stock now.
