Author Topic: [IC] TOMAK79 ; Tenting Split 75% from SR Industry  (Read 11527 times)
Offline syryan
    • www.kbdmania.net
« on: Sat, 21 September 2024, 02:06:38 »
* TOMAK79
Tenting Split 75%
* Specifications
- Layout : 75% + @ (B,H,Y,7)
- Mounting : PCB Socks Gasket / Top
- Typing Angle : 7°
- Tenting Angle : Left 9°, Right 8°
- Front Height : 10.2mm
- PCB : Solder, Hot Swap
- Weight : 3.9Kg ( Unbuild ) Left : 1.8Kg, Right 2.1Kg
- Matetial : Aluminum 6063 T6
- Color : Silver, Black, E-White
* Layout
309992-0
Soldering
309994-1
Hot Swap
* Standard Kit
- Top Case
- Bottom Case
- Carry Case
- Microfiber Towel
- Case Screw
- Mount Screw
- Bumpon
- Socks Gasket
- Wrist Rest(Caron Fiber)
- Neodium
- Badge (PC)
* Extra
- Plate ( Aluminum, PC, Carbon )
- PCB 1.6t ( Solder, Hot Swap )
* Exploded
309996-2
* Outline Dimension
309998-3
* Proto _ Silver
310000-4310002-5
310004-6310006-7
310008-8310010-9
310012-10310014-11
* Proto _ Black
310016-12310018-13
310020-14310022-15
* Faq
- Coming soon
* Venders & Priceing
- Coming soon
* Sound Test
* Discode Link : https://discord.gg/T3Gc5J9fP5
* Instagram Link : https://www.instagram.com/p/C-MtIXQSI-V/?img_index=1
                         https://www.instagram.com/p/C-MtOIcymeM/?img_index=1[/size][/size]
« Last Edit: Sat, 21 September 2024, 02:23:16 by syryan »
Offline DirtyGingy
Re: [IC] TOMAK79 ; Tenting Split 75% from SR Industry
« Reply #1 on: Sat, 21 September 2024, 06:34:18 »
I don't know how I would manage having a "proper" set of caps for this, but it's a very functional way to do B in both hands while being able to connect the halves
Offline IOVERCALLHISTIOCYTES
« Reply #2 on: Sat, 21 September 2024, 09:05:07 »
Other split users: Where do you hit for spacebar?
Never knew till split board use, but I only space left thumb and right at the gap between 2.25u and fn key as set up here.
Neat board
Offline Damage
« Reply #3 on: Mon, 30 September 2024, 23:16:04 »
Looks like the Korean group buy has opened. I assume there will be international vendors? What is the timetable for the international group buy? More info, please!
« Reply #4 on: Fri, 01 November 2024, 17:11:10 »
https://klc-playground.com/products/gb-tomak79-tenting-split-75?variant=42838283419854
Buy’s up
This doesn’t seem like it’s gonna go be on the geekhack group buy page.
Offline lilysmith1098
    • mapquest directions
« Reply #5 on: Sat, 02 November 2024, 04:32:01 »
Offline GorkasVillum
« Reply #6 on: Wed, 04 December 2024, 05:49:07 »
I use the right 2.75u in my splits
Neat board
Offline k-y
« Reply #7 on: Mon, 10 March 2025, 13:53:40 »
Buy’s up
The GB page on KLC has disappeared; does this mean it's only direct now?
Offline robertoliver
« Reply #8 on: Mon, 10 March 2025, 20:57:29 »
https://klc-playground.com/products/gb-tomak79-tenting-split-75?variant=42838283419854 geometry dash lite
Buy’s up
The link is broken. Can you reup it?
« Reply #9 on: Mon, 10 March 2025, 21:56:19 »
I have no involvement in this buy
Just like split boards. No idea what’s up w it now.
