Author Topic: [Instock] Huano Iced Coffee Linear Switch/Picnic Works  (Read 7146 times)
Offline DashanYYY
    • Unikeys
« on: Mon, 23 September 2024, 14:12:01 »
Discord:https://discord.gg/xprJb8Ta26
310061-0
Price
Price:
Premiere Price:0.3USD per switch
Switch Specifications
Switch type: Linear
Designer: Picnic Works
Manufacturer: Huano
Stem material: L1
Top Housings: POK
Bottom Housing: PA66 + 30% fiberglass
Operating Force: 42±5g
Bottom-out Force:  52g±5g
Pre-travel: 2.0mm±0.2mm
Total Travel: 3.5±0.2mm
Spring: 22mm KOS Single-Stage extended spring
Factory Lubed: Yes!
310063-1
310065-2
310067-3
Materials:
Unlike previous Huano switches which mostly use POM as the stem material, the Iced Coffee switches come with an L1 stem. The L1 blend material can be considered as Huano's LY. When compared with POM, L1 has a lower density and is softer.
The POK top housing is known to be durable and smooth. It is also good for mitigating top-out sound. Picnic Works chose POK as the top housing material because they want the bottom-out sound to stand out while keeping the top-out sound as subtle as possible. That is also the major reason why PA66 with 30% fiberglass was chosen to be the bottom housing material.
Fiberglass is a necessary additive during nylon injection because it helps with shaping. However, in the switch industry, engineers and enthusiasts noticed that PA66 with fiberglass could help bottom-out sound more clacky and higher pitched. After such discovery, PA66 + 30% fiberglass has become a standard choice when someone is trying to make a clacky switch.
In conclusion, the Iced Coffee switches come with a softer-than-usual bottom-out feel, but the sound is not deep or muted. With the help of fiberglass in the bottom housing, its sound signature can be defined as medium clack. The POK top housing helps eliminate unwanted extra noises and sound, which would help them to sound overall very clean and solid.
310065-4
Form of Sales
Time of Sales
September 23rd
Offline RonaldNNguyen
Re: [Instock] Huano Iced Coffee Linear Switch/Picnic Works
« Reply #1 on: Mon, 30 December 2024, 20:57:55 »
Price
Price:
Switch type: Linear
Manufacturer: Huano
Stem material: L1
Top Housings: POK
Factory Lubed: Yes!
Materials:
Form of Sales
Time of Sales
September 23rd
I really like how they make informed decisions when buying.
« Last Edit: Tue, 31 December 2024, 03:07:08 by RonaldNNguyen »
