Author Topic: [IC] Mage Studio Love65 Custom Keyboard Barebone Kit  (Read 5423 times)
Offline BerserKeys
  • Build more powerful weapons as you GO BERSERK.
    • BerserKeys
« on: Tue, 01 October 2024, 22:32:59 »
Join our Discord
Follow us on Instagram
Hey there!
We are so excited to partner with Mage Studio to bring you this elegant custom mechanical keyboard!
KEY FEATURES:
Love Letter Design
The Love65 features an enchanting love letter contrast colour design that transforms each keystroke into a poetic expression. Its bold colour contrasts create a visually striking effect, ensuring that your keyboard not only performs exceptionally but also captures attention with its distinctive, artistic flair.
12 Stunning Colourways
Choose from a curated selection of 12 stunning colourways to perfectly match your personal style. From vibrant, eye-catching Red and Black to elegant, understated Milk White, the diverse palette allows you to express yourself and complement any workspace with ease.
Spray-Coated with Glitter
Infuse a bit of magic into your typing with the Love65's spray-coated glitter finish. This enchanting coating creates a dazzling shimmer that reflects light, adding a touch of sparkle and elegance to your everyday typing experience.
Aluminium Badges and Weight
The Love65 is adorned with an intricately designed aluminium badges (engraved nameplate and stamp) and a well-balanced weight. These elements are not only aesthetically pleasing but also contribute to the keyboard’s solid, premium feel, enhancing both its visual appeal and tactile satisfaction.
Flex Cut Hot Swappable PCB
The Love65 features a 1.2mm per-key flex cut PCB that is hot-swappable for easy switch changes. It supports both ANSI and ISO layouts with deep and thocky sound oriented, focusing on a clean and customizable typing experience.
PRODUCT PHOTOS:
COLOURWAYS:
SPECIFICATION:
Brand: Mage Studio
Product Type: Mechanical Keyboard Barebone Kit
Model: Love65
Layout: 65% ANSI (ISO Supported)
Number of Keys: 67
Front Side Height: 18mm
Mount Type: Plate Gasket Mount
Case and Weight Material: CNC Aluminium Alloy
Colouring Process: Spray-Coated
Badge (Stamp): Aluminium with Engraved Rose Stamp
Badge (Nameplate): Aluminium with Engraved Feather Pen Nameplate
Colours: Black and Pink / Blue and White / Green and Milk White / Milk White / Pink and Milk White / Pink and White / Purple and White / Red and Black / Red and Milk White / Red Velvet and White / Tiffany Green and White / Yellow and Milk White
Stabilizers: Plate Mount Stabilizers (PCB Mount Stabilizers Supported)
PCB: 1.2mm Per-Key Flex Cut, Hot-swappable, No Backlight (ANSI / ISO Supported)
Plate: Per-Key Flex Cut FR4 Plate (Default ANSI Layout)
Acoustic Package: Poron Foam + IXPE Switch Pad + Poron Bottom Foam
Connectivity: Tri-Mode (Wired /2.4GHz / Bluetooth)
Charging Port: 1 x USB-C
Latency: Wired: 3ms / 2.4GHz: 5ms / Bluetooth: N/A
Compatible Software: Self-Developed Software
Compatible System: Windows / MacOS
Battery Capacity: 2500mAh
GROUP BUY:
The group buy is set to start on our website at 12:00am on Monday 30 September and end at 11:59pm on Sunday 27 October (AEST).
There are strict time limits, but no limit to the number of items you can order.
After the group buy ends, all order information will be collected and forwarded to the manufacturer for production. Production and shipping time depends on several factors, but usually lasts 1-3 months.
UPDATES:
Waiting to receive sample products from Mage Studio. (27 July 2024)
Sample products have been shipped to content creators for reviews. (23 Aug 2024)
GB is going to start soon. (03 Sep 2024)
GB is open now. (30 Sep 2024)
« Last Edit: Wed, 02 October 2024, 01:58:08 by BerserKeys »
BerserKeys – Oceania Vendor
Website: https://berserkeys.com.au
Updates & Announcements: Discord / Instagram
Offline Silentism
Re: [IC] Mage Studio Love65 Custom Keyboard Barebone Kit
« Reply #1 on: Wed, 02 October 2024, 10:19:22 »
Posting an IC for a GB that's started already and its a flex cut board lol.
