Author Topic: WYSE 50 Keyboard tuning  (Read 17114 times)
Offline peterro
« on: Sat, 12 October 2024, 12:33:24 »
Hi all,
I started my career using a WYSE 50 terminal in the early 90's and thought it'd be cool to get one I could use now. After lots of reading and trial and error, it's ~sort of~ working but not usable yet. I think it's close but may need some minor adjustment.
To catch you up, this is what I've done. Got the keyboard and a Teensy 2.0 from https://1upkeyboards.com/shop/parts-and-tools/pjrc-teensy-2-0/ (the ebay one I first got didn't work). I used soarer's firmware 1.30 and applied the WYSE_WY50.sc configuration. Most of the details were from the following links:
https://geekhack.org/index.php?topic=52597.0
https://geekhack.org/index.php?topic=50883.0
I used the wiring diagram for the original 10-pin connector from this video at the 4:10 mark though I did swap the green and white as well as move the yellow to PB4 on the Teensy instead of PB7 like in the video which is more accurate to the original soarer pin-out:
Now getting to the problem I'm seeing. I installed QMK Toolbox to see what the keyboard was sending when pressing keys now that I'm getting some output. I noticed that the console showed multiple key codes when pressing one key. The key that was pressed is pretty much always one of the codes, but there are others which seem like line noise?
As an example, press 'a', and I get either 'era' or 'eqa' on the screen though usually 'eqa'. With the QMK key tester whenever pressing 'a', it shows the combination of 'e', 'q', 'a', and 'F5'. All the rest of the keys have similar 'noise' along with the correct key though the noise is different from key to key. It feels like if the 'noise' were gone, the board would mostly work correctly though there may need to be some remapping.
Anyway, any ideas what may be causing this? Is there some type of filter that may help or ???
Thanks in advance.
Offline peterro
Re: WYSE 50 Keyboard tuning
« Reply #1 on: Wed, 06 November 2024, 16:41:20 »
Sorry to reply to my own thread but it's been almost a month and over 500 views without a reply so did I possibly post to the wrong sub-forum or is there a better place for posting? I would have posted to the end of the original thread but the forum implied when I posted that it may not be best since it was so old.
Any recommendations would be appreciated.
Offline wjrii
« Reply #2 on: Thu, 14 November 2024, 12:12:19 »
This is the right forum, just not a ton of traffic these days, and you're down the rabbit hole pretty deep.  :) You might also try Deskthority if you can sign up properly, or ask on Reddit or a big Discord.  Soarer's is sort of a done-deal now, but if you find a solution built around Hasu's firmware, he's still around and very responsive.
