Author Topic: [Instock] Keebscape.co Kronos 60% Keyboard  (Read 6290 times)
Offline DashanYYY
    • Unikeys
« on: Tue, 15 October 2024, 14:29:21 »
kronos
A 60% Mechanical Keyboard Kit by keebscape.co
This is going to be an in-stock sale.
Keebscape.co Discord
Unikeys Discord
Instagram
Index
1. Introduction
2. Specifications
3. Renders and Photos
4. Availability
Introduction
kronos is the first custom mechanical keyboard kit by keebscape co.  It is an unassuming take on the classic 60% form factor O-ring mount design.  The chassis is comprised of a single piece of polycarbonate with an internal brass weight.  The weight fits through the bottom of the polycarbonate chassis in the shape of a minimalistic representation of Saturn.  Named after the Greek deity, Kronos (also written as “Cronus”, or “Cronos”), the board features subtle engravings reminiscent of Galileo’s earliest sketches of Saturn, from 1610 and 1616.  The sandblasted polycarbonate chassis in conjunction with RGB underglow from the PCB results in a pleasing diffusion of light throughout the uniform bezels.  This board does not offer anything particularly groundbreaking in terms of design or materials used in construction, but our hope is that it will provide an in-stock, high-quality 60% O-ring mounted custom keyboard kit at a relatively affordable price to those who want it.
Specifications
Chassis
Materials: Clear 'Frosted' Polycarbonate, Brass
Layout: WK
Typing Angle: 6.8 Degrees
Front Height: 17.4mm
Manufacturer: DDS
Mounting
Gummy O Ring
50A Durometer O Ring Included in Kit
PCB
Designed by Gondolindrim
Hotswappable (White) and Solderable (Black) Options Available
1.6mm Thick FR4
Gold Pads
JST Connector to Unified C5 Daughterboard
QMK/VIA Compatible
                                                 Solderable Layout
Hotswappable Layout
Remark: The plate included in the kit only supports 7U spacebars, but the solderable PCB supports both 7U and 6.25U spacebars.  This is because the PCB was designed to be a “universal” 60% PCB. I.e., it was designed to be compatible with a wide range of existing and future 60% O Ring keyboards, conditional on the JST position.  This goes both ways, meaning that solaris is compatible with “universal” 60% PCBs.
Renders and Photos
Renders by MiKeyDigit
Photos
Availability
Sale time: 2024, October 20th, 9:00 PM ET
Kit Price: $240 (Without PCB)
Number of Units: 100
Sale Format: In-stock (All of my friends hate GBs)
Vendors: Unikeys & KTechs
Unikeys: https://unikeyboards.com/?srsltid=AfmBOorVfn2f3cmhTJPhcWK7aKgM-e1KvsybOQ8du08r1R_KbKCjGfvX
Ktechs: https://ktechs.store/?srsltid=AfmBOopaATWykLqrQn2mTqkGc0vqBCPk6TLaPz11v13w3LP6biKkyEXa
Kit Contents
1x Chassis (Polycarbonate, Brass Weight)
1x Aluminum Switch Plate Anodized Black
1x Unified C5 Daughterboard + JST-JST Cable
1x 50A O Ring
1x kronos Carry Case
Bumpons
All necessary screws for assembly
Addons
Hotswap PCB - $40
Solder PCB - $35
Aluminum Switch Plate - $35
PP Switch Plate - $35
... (2 lines left)
« Last Edit: Fri, 18 October 2024, 16:01:58 by DashanYYY »
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
Re: [Instock] Keebscape.co Kronos 60% Keyboard
« Reply #1 on: Fri, 18 October 2024, 20:33:43 »
nice
Offline DashanYYY
    • Unikeys
