Author Topic: Best stabs for 1.2mm PCB?  (Read 5042 times)
Offline jackcalico
« on: Sun, 27 October 2024, 14:05:02 »
Which stabs would you recommend for 1.2mm PCB (no shims)?
Re: Best stabs for 1.2mm PCB?
« Reply #1 on: Sun, 27 October 2024, 16:19:37 »
If we're talking Cherry MX-compatible...
1. Plate-mounted.
2. Screw-in stabs.
Are you using a 1.2mm PCB because you need thickness for a thin layer of foam in-between the switch and PCB?
« Last Edit: Sun, 27 October 2024, 16:22:54 by Findecanor »
Offline pixelpusher
« Reply #2 on: Sun, 27 October 2024, 17:49:28 »
Hard to go wrong with TX stabilizers.  They get my vote.
Offline Pignity
« Reply #3 on: Wed, 29 January 2025, 11:11:10 »
type plus YIKB stabs, easily the best stab I have used, it has shims for 1.2mm I believe
Offline LavenderB
  • I believe in unix control supremacy
« Reply #4 on: Wed, 29 January 2025, 14:12:46 »
+1 for TX 1.2mm stabs.
Safa | 1993 UK ISO-DE Model M  | Frog TKL | 3d printed bakeneko | Akko 5075s
Offline popollopop
« Reply #5 on: Fri, 14 February 2025, 19:09:04 »
TX 1.2mm!
