Author Topic: [GB] ZOOM75 TIGA & PAD - Redefining Sound and Customization, Inspired by Ultrama  (Read 2082 times)
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
JOIN THE GB HERE
GB Info for TIGA
GB Date: November 4th - November 18th
Estimated Shipping Time: February
Media and Typing Test
Key Features:
1. New sound concept: Cork Sandwich for a unique typing sound.
2. Multiple mounting systems: 4 options for versatile typing experiences.
3. Finish Treatment: Acustatic Coating with two new colors, Forest Green and Grape Purple.
4. Upgraded screen and LED technology.
5. Customizable badge, soul grille, and Dual-Wing design.
New Custom Sound Options:
●Soft (Poron Foam): Durable with a muted sound.
●Crisp (Cork Sandwich): Crisper sound, no traditional foam.
●Standard (Classic Foam): Higher-pitched sound.
New Options for Custom Soun
For the first time, we’re offering multiple foam options giving you even more control over the sound of your keyboard.
●Soft - Poron Foam : Poron foam offers excellent durability and fatigue resistance, ensuring consistent sound performance over time. With a muted sound profile it makes it the perfect option for office use. The darker color when compared to traditional foam also offers an overall sleek look.
●Crisp - Cork Sandwich : For the first time, we’re introducing the “cork sandwich,” perfect for those who prefer a board without traditional foam. This cork layer produces a crisper sound for a unique typing experience.
●Standard - Classic Foam : Classic Foam tends to change the sound profile over time while offering a higher-pitched sound profile.
Our easiest build ever - 30 min build
Building the ZOOM75 TIGA is easier than ever, with an estimated build time of just 30 minutes.
We’ve simplified every step:
●Pre-installed Components: The batteries, daughterboard, knob, screen and internal weight are already installed.
●Pogo Pin Connections: Plug-and-play design with pre-connected soft cables ensures a smooth assembly with consistent sound quality.
Upgraded Finish Treatment—Acustatic Coating
We’re introducing Acustatic, a cutting-edge electrostatic spray technology that delivers vibrant colors and superior consistency.
The smooth, refined surface achieved by a 220-mesh fine spray coating offers a premium feel and finish.
Seamless Screen and Knob Integration
We’ve always worked to push the boundaries of what a keyboard can offer.
With that in mind, we saw many in the community asking for a design that features both a screen and knob while keeping the popular 75% layout.
Usually, adding a knob means sacrificing screen size, however, this time we’ve changed things up.
By using a scroll wheel design for the knob, we’ve managed to keep the screen large while still offering the functionality of a knob.
While default, the screen can be swapped out for badge inserts or keycaps, giving you even more customization options.
Upgraded Screen
Continuing on the trend of redefining the ZOOM75 TIGA, we’ve worked to make sure the screen is at the highest level. Brand-new Structure, significantly reduces the risk of damage.
●Twice the memory, more features, larger image support.
●Upgraded Communication Interface, boosting image transfer speed by four times.
●High Resolution and 60 FPS, bringing a smoother, higher-quality image than ever before.
The result is our highest quality screen to date bringing with it more information to you at the highest quality and smoothest framerate.
Not Just a Keyboard: A Showcase for Creativity
Beyond functionality, the ZOOM75 TIGA serves as a showcase for your passions:
●LEGO Display Mode: Integrate your favorite LEGO® builds.
●Pop Mart Collector: Display your favorite figurines.
●Customizable Dual-Wing Design: Download source files to 3D print custom winglets and make this keyboard truly your own.
The badge area above the USB port and the Dual-Wing design on the back open endless possibilities for personalization. It’s more than just a keyboard—it’s an extension of you.
15 Stunning Colorways
Introducing 2 new colors this year - Forest Green and Grape Purple
All 15 colors: Forest Green, Grape Purple, Gunmetal Gray, Cafe Brown, Milk Tea, Aquamarine, Sky Blue, Milky Green, E-White, Anodized Black, Anodized Lavender, Strawberry Icecream, Black, Scarlet Red, White.
The finish treatment for Milk Tea, Aquamarine, Black, and White is Acustatic with Giliter.
LED Upgrade
We’ve upgraded the PCB LEDs with improved wavelength, color range, and brightness. The overall lighting area is now twice as large.
ZOOM 75 TIGA Specs & Features:
Layout: 75%
Material: 6063 Aluminum
Full CNC
Battery Capacity: 8000mAH
Foam: Standard, Poron, or Cork (Optional)
PCB: 1.2mm flex cut PCB / 1.6 non-flex cut PCB
(both ISO and ANSI compatible)
Customizable options:
Rear Winglets, Rear Badge, Soul Grille
4 mounting systems:
Top Mounting, Elastic Bar Mounting,
Silica Gel Mounting and Split O-ring Mounting
Typing angle: 6.5°
Module Options: Screen (Default), Badge
Force Break Mod: Yes
Front height: 17.57mm
Keyboard width: 323.77mm
Connection: Wired, 2.4G, Bluetooth
ESD Protection
VIA supported (QMK not supported)
Catchball System: Yes
Screwless Install: Yes (Except TOP and Mount Split-O-ring Mount)
ZOOMPAD TIGA
ZOOM75 TIGA adds a matching color numeric pad as an option. It can improve the work efficiency and at the same time let you experience a different kind of customization.
JOIN THE GB HERE
ZOOMPAD Specifications
Case Material: Aluminum(FuII CNC)
Typing angle: 6.5°
Connection: wired, 2.4G, Bluetooth
Mounting systems: Top Mounting, Silica Gel Mounting
Battery Capacity: 600mAh
Pricing
[GB] Meletrix × Elipsis Mercury Wrist Rest
Full-aluminum and weighty wrist rests. The design is inspired by “flowing metal” and will be available in 15 colors with 3 different processes and 2 additional sizes.
80%: 358mm x 80mm x 19mm
65% & 75%: 322mm x 80mm x 19mm
60%: 295mm x 80mm x 19mm
]JOIN THE GB HERE
EXCLUSIVE OFFER
Group Buy Free Order Giveaway Events
Event 1: Free Order Giveaway--- UP TO $500
Event Rules:
●How to Participate: Click the giveaway bot in the #zoom75-tiga-discussion channel on Discord to join.
●Winner Verification: Winner will be pinged in the channel and must provide their order number within 24 hours.
Orders placed after the giveaway ends will be disqualified, and the prize will be re-rolled for another participant.
●Vendors Included: Customers ordering from any authorized vendor are welcome to participate.
Platform:
●Join us on Discord in the #zoom75-tiga-discussion channel.
●Discord
Event 2: The Ultimate Grand Prize--- $500 GIFT CARD
Event Rules:
Winner Selection: Winner will be pinged in the channel
Platform:
●Discord
Usage Terms:
●The gift card must be used for a purchase that includes at least one TIGA unit.
●Redemption of the gift card is required within three days of being awarded, after which it will expire.
Social Media Channels
For more details and updates, you can join the Discord group
You are also welcome to come and join us on our social media channels:
Instagram
Facebook
Twitter
FAQ and Support Information
We’ve got you covered! For common questions about the ZOOM75 TIGA, payment options, shipping details, and more, check out the FAQ section below:
Q: What mounting options are available for the ZOOM75 TIGA?
A: It comes with four mounting systems: Top Mounting, Elastic Bar Mounting, Silica Gel Mounting, and Split O-ring Mounting.
Q: What is the estimated shipping time?
A: The estimated shipping time for this GB is February.
Q: Is international shipping available?
A: Yes, shipping is available globally through our authorized vendors. For more detailed questions, feel free to reach out through our Discord channel or customer support.
What feature of the ZOOM75 TIGA are you most excited about? We’d love to hear from you! Share your thoughts in the comments below or in our Discord channel.
Your feedback helps us bring the best possible experience to the community.
Offline Ckeeb
    • MELETRIX
GB open now!
