Author Topic: Blank Replacement Keys for Majestouch  (Read 2463 times)
Offline Jimi
« on: Thu, 28 October 2010, 22:21:08 »
Well I've been looking for a while for to find a Tenkeyless Otaku Majestouch with Blues, but since it was only on sale for a limited time, I doubt I'm going to find one. Basically, I've decided to get the normal Tenkeyless Majestouch, and then buy blank key replacements (this will let me have a flat windows key also). Does anybody know a good place where I can order a set that is compatible, I'm sure that they probably don't have to be Majestouch specific to work? I've read someplace that Elitekeyboards used to sell them, but I can't find them.
Offline Kairxa
« Reply #1 on: Thu, 28 October 2010, 22:36:33 »
Keyboardco sells them, BUT beware of their shipping rate.
Offline Jimi
« Reply #2 on: Fri, 29 October 2010, 00:35:56 »
Thanks for the quick response. Looking like it'll be around $50 if I ordered it from there. Does anyone know if there is some means of getting them cheaper? Is there for example another keyboard that uses the exact same keys and has a blank set that if I looked for that would be cheaper etc...? Just trying to see if there's something easier before I drop $50 on blank keys.
Offline Kairxa
« Reply #3 on: Fri, 29 October 2010, 05:38:20 »
Of course! http://www.daskeyboard.com/model-s-ultimate/
Unfortunately, it's not tenkeyless.
Offline Jimi
« Reply #4 on: Fri, 29 October 2010, 09:54:11 »
Quote from: Kairxa;240095
What I meant was another keyboard that I could use their set of blank keys on the filco. Sorry for the poor articulation.
Offline Kairxa
« Reply #5 on: Fri, 29 October 2010, 10:59:41 »
Hmm, AFAIK, no other keyboard producer that has blank keyset replacement. Except KBC.
Unfortunately again, KBC is located in China, so the shipping will also be ridiculous.
