Author Topic: Charue Sunsetter R2 VIA file  (Read 5655 times)
Offline bigmaxnonions
« on: Wed, 20 November 2024, 20:30:52 »
Hello!
I am having some issues flashing my Sunsetter R2 on QMK and am running into this issue where its not recognizing the usb?
311051-0
IDK, I don't use QMK very much so I don't know how to fix it.
Does anyone have the VIA file for the board?
Many thanks!
Offline zegonix
Re: Charue Sunsetter R2 VIA file
« Reply #1 on: Thu, 21 November 2024, 02:10:44 »
did you put your keyboard into bootloader mode?
« Reply #2 on: Thu, 21 November 2024, 06:59:56 »
Update: I got it to work, not really sure how though, but hey, Im not complaining
Offline zegonix
« Reply #3 on: Fri, 22 November 2024, 05:55:02 »
depending on the design of the pcb, you need to actively put your board into bootloader mode (mode where qmk toolbox can flash firmware). from what i read, this was most likely your issue. many qmk firmwares will switch into bootloader mode if you hold escape while connecting the board.
