Author Topic: [IC] Awekeys Metal 10u Spacebar - 4 Color Options - Vendor & Price Update  (Read 11763 times)
Offline PulseForge
Hello everyone!
As a passionate enthusiast of vintage and custom mechanical keyboards, I've always been drawn to the classic designs of the 1980s and early 1990s, particularly those that featured the iconic 10u spacebar. There's something about the larger spacebar that adds to the nostalgia and unique aesthetic of those old-school setups. Inspired by the Geonworks W1-AT, which brings the 10u spacebar back to life in a modern context, I decided to collaborate with Awekeys, a company renowned for its high-quality metal keycaps. Together, we aim to create a spacebar that honors the past while integrating seamlessly with today's keyboard kits. After discussing manufacturing and compatibility with Awekeys' engineering team, we confirmed that this project would work perfectly with current 7u spacebar-compatible kits, ensuring an easy installation and flawless performance on a wide range of custom keyboards. I'm excited to bring this piece of keyboard history back to life for fellow collectors and enthusiasts.
SPEC
Manufacturer: Awekeys
Profile: Cherry
Material: Recycled Metal
Length: 10u (approx. 190mm / 7.48 inches)
Colors: Satin Gold, Satin Silver, Satin Copper, and Titanium Black
Compatibility: Cherry MX Stem and 7U spacebar stabilizers
GB Date: Feb 2025
Price
Titanium Black $69
Satin Copper $69
Satin Gold $89
Satin Silver $89
Vendor List
US: ClickClack & DangKeebs
CA: Desk Hero
UK: Prototypist
AU: KeebznCables
SG: ktechs
Global:Awekeys
Renders
Sample Photos Update
If you are interested in collaborating with me, please contact me on Discord (#PulseForge) or through e-mail (PulseForge_k@outlook.com).
« Last Edit: Sun, 09 February 2025, 21:17:49 by PulseForge »
Offline itswh
Re: [IC] Awekeys Metal 10u Spacebar
« Reply #1 on: Wed, 04 December 2024, 01:05:59 »
10U never fails, but is there any price estimate going on for this
Offline PulseForge
« Reply #2 on: Thu, 05 December 2024, 23:23:31 »
I'm currently discussing the pricing with Awekeys and will update soon in the IC form.
Offline Nebulonix
Re: [IC] Awekeys Metal 10u Spacebar - 4 Color Options
« Reply #3 on: Sun, 08 December 2024, 19:58:19 »
I am curious about the weight of these spacebars of 10 size. Do you have a reccomended spring weight for the spacebar?
Offline PulseForge
« Reply #4 on: Mon, 09 December 2024, 21:38:19 »
The spring weight needs to be 100gf+ I think. Will keep you guys updated when I get the sample keys.
Offline Nebulonix
« Reply #5 on: Wed, 11 December 2024, 19:45:58 »
Sounds great! GLWTIC
Offline Mainige
« Reply #6 on: Fri, 13 December 2024, 04:05:19 »
Let's GO!!
« Last Edit: Fri, 20 December 2024, 02:56:11 by Mainige »
Offline PulseForge
Re: [IC] Awekeys Metal 10u Spacebar - 4 Color Options - Sample Photos Update
« Reply #7 on: Fri, 20 December 2024, 03:07:42 »
Today I received the sample 10U spacebar form awekeys, this bad boy is longer than my expected.
Offline Nebulonix
« Reply #8 on: Tue, 24 December 2024, 03:01:46 »
Can't wait to hear the sweet sound of the 10U metal keycap!
Offline Ceyx
« Reply #9 on: Sun, 29 December 2024, 10:37:21 »
Has a little bit too much shine to it on the second picture. Almost can see lines, or am I imagining things? Needs some more sand blasting or whatever technique is used?
Offline PulseForge
« Reply #10 on: Mon, 30 December 2024, 21:00:05 »
I've seen it in person and it looks fine. I'll make a video and upload it later so you all can check it out!
Offline Ceyx
« Reply #11 on: Wed, 01 January 2025, 22:51:23 »
 :thumb:
Offline Ceyx
« Reply #12 on: Thu, 02 January 2025, 06:43:34 »
How does one delete comments?
« Last Edit: Fri, 10 January 2025, 01:27:48 by Ceyx »
Offline PulseForge
Re: [IC] Awekeys Metal 10u Spacebar - 4 Color Options - Vendor List Update
« Reply #13 on: Sun, 09 February 2025, 20:21:01 »
Price
Titanium Black $69
Satin Copper $69
Satin Gold $89
Satin Silver $89
Vendor List Update
CA: Desk Hero
UK: Prototypist
AU: KeebznCables
SG: ktechs
Global:Awekeys
« Last Edit: Sun, 09 February 2025, 21:18:47 by PulseForge »
Offline dvorcol
  • Discord: dvorcol_5071
Re: [IC] Awekeys Metal 10u Spacebar - 4 Color Options - Vendor & Price Update
« Reply #14 on: Wed, 12 February 2025, 20:33:09 »
GB live now: 12 - 20 February 2025.
