Author Topic: Unknown Bro Cap Keycap  (Read 6758 times)
Offline DaBubbs
« on: Thu, 05 December 2024, 11:45:40 »
Does anyone know what the name of this Bro Cap keycap is called?
311276-0
I forget exactly how I ended up with it, given that it is MX. I think that I ordered a Topre Lycan years ago and I was sent it by mistake and told that I could keep it. Whatever the reason, I cannot find the certificate card for it.
When you are dead, you don't know that you are dead. It is difficult only for the others.
It is the same when you are stupid.
Offline nickheller
  • Cherry ML life
    • hickneller.com
Re: Unknown Bro Cap Keycap
« Reply #1 on: Thu, 05 December 2024, 15:48:12 »
This is a Keyforge Orochi, it seems to be the Volcanic colorway. https://keycap-archivist.com/maker/keyforge/orochi/41bbbccf/
Offline olporr
« Reply #2 on: Fri, 06 December 2024, 02:17:14 »
These look so cool, and I’m not much of a keyboard/keycap person. Do these work on a backlit keyboard? Or do they not illuminate?
Offline DaBubbs
« Reply #3 on: Fri, 06 December 2024, 15:01:24 »
Great, thanks!!!
Offline DaBubbs
« Reply #4 on: Fri, 06 December 2024, 15:04:26 »
I do not believe they illuminate, but I do not have any backlit keyboards. I mostly use Topre Realforce TKL keyboards.
The keycap is thick enough that I am not sure if any light would pass through it. I could be wrong though.
