Author Topic: Highest quality readily available keyboards  (Read 64030 times)
Offline TomahawkLabs
Re: Highest quality readily available keyboards
« Reply #50 on: Mon, 13 January 2025, 12:11:22 »
Everyone seems to forget that Matias still makes full size keyboards using their own switches that have the same stem, pin location, and body of the SKCM/SKCL switches. They are build similar to MX style, buy with the physical features of Alps. I would say if you want a non-MX style keyboard, full size, and brand new, Matias is probably the only off-the-shelf option. Specifically the Matias Tactile Pro. If you get a wild hair, you could swap the switches with vintage Alps.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline iri
« Reply #51 on: Mon, 13 January 2025, 12:36:26 »
I remember my Matias board. Its quality was ****. I read a few reviews online now that you've mentioned them, and a lot seem to mention issues such as ghosting. Not sure if that's due to switches.
-Ray Bradbury
« Reply #52 on: Mon, 13 January 2025, 12:38:40 »
Bummer. Since they make the switches, they are also the only ones to make boards for it (outside custom stuff). The only non-MX style switches are all low profile/funky and I can't recommend any of that. Hopefully you find something!
SA: Camping
Offline iri
« Reply #53 on: Mon, 13 January 2025, 12:56:39 »
ok let's look at my own reviews lol
i hate everything connected to matias mini quiet pro.
fyi, matias quiet pro mini isn't any good.
quiet pro feels exactly like a crisprier rubber dome with spring underneath. and the board's quality is rubbish. switches are inconsistent. they feel very different when center pressed, off-center pressed, pressed in different sides, etc. and the switches themselves feel different. and the keycaps aren't even.
-Ray Bradbury
Offline iri
« Reply #54 on: Mon, 20 January 2025, 17:57:17 »
I've got the Niz delivered. I wouldn't call it remarkably high quality (some keys are inconsistent), but it's interesting and feels similar to Topre, but I don't have the problems that I had with Topre when typing on the Niz. Also, the 35 weight is quite unusual =)
By pure coincidence, on the same day I received two replacement PCB's for my broken AEK =)
-Ray Bradbury
Offline phinix
« Reply #55 on: Tue, 21 January 2025, 13:25:40 »
AEK? what switches do you have there?
What is best AEK, switches wise? I guess its hard to find one nowadays, for reasonable price?
« Reply #56 on: Tue, 21 January 2025, 13:35:27 »
You didn't ask me, but I love the AEK/Alps SKCM/SKCL switches. There are 2 main versions, the AEK1 and the AEK 2. The AEK 1 uses a different "eject" button shape, but the core layout and PCB seem interchangeable. The AEK 1 had SKCM Orange, and SKCM Salmon switches. Both are tactile switches with the salmons being a bit lighter than the oranges. The AEK 2 used SKCM Salmons (rarely) and are mostly found as Damped Creams and Damped Whites. Both damped switches appear to feel the exact same to me, just a slider color difference.
Best place to get an AEK or AEK 2 is Ebay. You can find them from $60 on a good day to $120 for someone who "knows what they have". I would say the Salmon switches are my outright favorite of the switches that you can find in that keyboard.
I own 7-8 AEK keyboards and daily drive a AEK2 with Damped Creams at work. I have spent the last few years only looking at Alps switches and have a fair few in my collection ready for restoration. I was actually working on some Damped White switches over the weekend.
SA: Camping
Offline phinix
« Reply #57 on: Tue, 21 January 2025, 13:47:00 »
I'm guessing white ones are clicky?
I prefer tactile or linear, but for alps I heard its best to take tactile, like orange or salmon? I like heavy switches so would prefer heaviest version, so salmons then?
« Reply #58 on: Tue, 21 January 2025, 14:08:41 »
The Damped Whites are tactile like the Damped Creams. Alps did make white switches that were clicky (which I really enjoy), but they are not found on the AEK or AEK2. I have 2 different linear switches and I have nothing nice to say about them, because it's a linear switch.
If you are into smaller boards that still use ADB, check out the Apple Keyboard M0116. It has both salmon and orange options. I am playing with an orange and a salmon M0116 and I would say its less "heavier" and more "more tactile". I would have to crack some switches open to check, but it feels like the hump to get over on the orange is smaller than the salmon. So it's isn't as much the weight of the spring vs the heft of the hump.
My pick would be and AEK 1 or M0116 with SKCM Salmon switches.
SA: Camping
Offline phinix
« Reply #59 on: Tue, 21 January 2025, 14:23:35 »
Thanks for sharing your knowledge :) Sounds like AEK1 and salmon is for me. Time to do some searching on ebay :)
Is it expensive to get some cable with converter to modern pc?
Oh, one more thing - are there any other keyboards like Lunar AEK 65%? This would be ideal for me.
« Last Edit: Tue, 21 January 2025, 14:26:27 by phinix »
« Reply #60 on: Tue, 21 January 2025, 15:23:17 »
The only one I can think of off the top of my head would be an AEK60, which I don't think you can find anymore, but the ADK64 could be what you are looking for.
SA: Camping
Offline phinix
« Reply #61 on: Tue, 21 January 2025, 15:30:28 »
oh, I hate 60%.
I think I remember Frog TKL had alps pcb, I need to look into that.
EDIT: just found it, also Tiger Lite is possible to build with alps!
Anyone selling salmon alps switches? :D
« Last Edit: Tue, 21 January 2025, 15:47:01 by phinix »
« Reply #62 on: Tue, 21 January 2025, 16:05:50 »
oh, I hate 60%.
Be aware, the switches top row of AEK keyboards are rotated 90 degrees. The keycaps also have their own unique profile so cases may look a bit wonkey.
SA: Camping
Offline phinix
« Reply #63 on: Tue, 21 January 2025, 16:17:25 »
oh, I hate 60%.
I see. So if I want to use AEK, then use that keyboard only. If I want to use its keycaps on other keyboard, then not F row. Got it.
« Reply #64 on: Tue, 21 January 2025, 16:32:32 »
More or less, yes.
SA: Camping
Offline iri
« Reply #65 on: Tue, 21 January 2025, 17:10:42 »
Linearised Orange Alps. They are my favourite switch.
My AEK cost me 250 quid on ebay, but it was in a pristine condition.
-Ray Bradbury
Offline HungerMechanic
« Reply #66 on: Tue, 21 January 2025, 20:20:43 »
Are you saying that the Salmon are more tactile than Orange, without having a heavier spring?
If I may ask, how do you find the Cream / Damped Cream and Whites in comparison?
« Reply #67 on: Tue, 21 January 2025, 20:58:23 »
It is hard to put into words, but it doesn't feel like a 67g linear switch vs a 72g linear switch. It feels like the hump to get over salmons is bigger, and requires more force, than the orange, which has a much less pronounced bump.
I think the damped switches are great. I just got done lubing and assembling some damped whites tonight. To my fingers the damped cream and damped white switches feel identical. I think the color difference was production/marketing and not a new design. The tactility of the damped switches is closer to the tactility of the salmons.
Out of the switches I have in my collection
1. SKCM Blue - Feels good, could be even better after cleaning/lubing, I can see why people love these switches
2. SKCM White - also feel good, not as good as blue, but still good
3. SKCM Salmon - My favorite tactile switch
4. SKCM "Taxi Cab" Amber - My favorite clicky switch. The best balance of sound and feel
5. SKCM Orange - light tactility, good overall feel
6. SKCL Yellow - its linear, nothing to comment about. it goes up and it goes down without binding
7. SKCL Green - again...
8. SKCM Black - currently disassembled in prep for round 1 of the cleaning process but offered nice tactility, nothing ultra special as I remember
9. Damped White - My office pick if you work with other people, great feel with a rubber dampener on the slider
10. Damped Cream - same as Damped White
11. Bonus non-standard switch - Heavy Blue. It's a customer spec blue. Hand marked with a blue line down the center and a heavy spring. I cannot understate how much force it takes to press down that switch.
12. Alps Locking - fun to see and play with, but wouldn't make a good keyboard
SA: Camping
Offline iri
« Reply #68 on: Mon, 27 January 2025, 05:29:38 »
Orange Alps' tactility feels to me like a bit of dirt on top of a linear switch.
Now Brown Alps are really tactile.
-Ray Bradbury
Offline phinix
« Reply #69 on: Mon, 27 January 2025, 06:05:40 »
For me MX Browns feel like that - like some dirt on top of linear switch :)
« Reply #70 on: Mon, 27 January 2025, 08:26:44 »
Funny you say that. I just had someone on ebay pull the keyboard out of an IBM 5140 so I can harvest the SKCM Browns. Very excited to feel how the feel. I am most excited to look at how the do the tactility. It's different than the usual metal leaf.
SA: Camping
« Reply #71 on: Mon, 27 January 2025, 08:44:32 »
My impression is that there is very little difference between salmon and orange, with most people giving the nod to orange.
Similarly, that there is very little difference between dampened white and dampened cream, with most people giving the nod to cream.
There is no doubt that condition and cleanliness make a huge difference in any case.
And "Northgate Bob" swore that there was no difference at all between blue and 1st generation white.
- D Trump 2026-10-24
« Reply #72 on: Mon, 27 January 2025, 09:47:25 »
I agree similarly with the orange/salmon. It was a lot of going back and forth between the two and it wasn't clear which one was better. With the boards I was comparing it felt as if the salmon had a bigger bump to go over and the orange started depressing with less initial force. Being they were used in the same boards I would assume it would be a minor change between the two. My current ambitions are to collect every mainline (not counting SKCL Striped Amber) Alps SKCM and SKCL switch. Fully broken down, cleaned, and lubed. Very time consuming, but the results do speak for themselves.
The process starts with disassembling the switch into: Slider, Top Housing, Lower Housing, Contact Leaf (if tactile/clicky), Spring, Switchplate, and Switchplate Contact Leaf. The Slider, Top Housing, and Bottom Housing get cleaned by hand with Q-Tips and iso alcohol to remove any dust, dirt, grime, nasty off before heading to the ultrasonic cleaner. The Spring, Contact Leaf, and Switchplate Contact Leaf all get a turn (15 minutes) in the ultrasonic cleaner. The solution I use is 2 denture tabs and a drop of Seventh Gen dish soap. Each part is then rinsed with distillated water before being dried off. The Slider, Top Housing, and Bottom Housing all get put onto a towel before each one is hand air dried with a pet blower. Once all the parts are cleaned, I apply some Teflon Silcon lubricant via brush to the Slider, Top Housing, and Spring during the re-assembly. The cleaned switches are then put in a plastic bag to keep them nice and clean until they can be used.
SA: Camping
Offline Vescovo Alessio
    • vescovorestauri
« Reply #73 on: Wed, 29 January 2025, 16:06:30 »
If the price is not a concern, as you say​...
maybe a Vescovo keyboard meets all your requirements​?
I have the one in the photo available​,​ combination of fini​​shes as follows:
- Base: American Walnut wood.
- Insert: Matte black anodized aluminum.
- Switches: Novelkeys-Kalih Cream (linear, self-lubricating POM, 55cN actuation force).
- Layout: US International (ISO).
- Compatibility: MacOS.
I can also build with different switches, different woods, windows compatibility, etc.
312125-0
312123-1
312127-2
312129-3
312131-4
312133-5
« Last Edit: Wed, 29 January 2025, 16:29:45 by Vescovo Alessio »
My mechanical keyboard project topic: https://geekhack.org/index.php?topic=121064.0
Offline FOURRINGS
« Reply #74 on: Tue, 09 September 2025, 00:50:37 »
have you checked out Mode keyboards? They have a great lineup, probably some of the best quality I am aware of that is in stock. Can also check out kbdfans or keychron.
GOOD CALL.. massive fan of the new MODE line up. Transparent PC hits the mark for me
Offline iri
« Reply #75 on: Tue, 09 September 2025, 11:22:14 »
I now have. I now realise I should have added a bullet point for 'no hackjob MX clones'  :(
-Ray Bradbury
Offline jony_m
« Reply #76 on: Tue, 04 November 2025, 13:56:54 »
Has anyone suggested the Norbauer Seneca?
nm, waitlist
Offline iri
« Reply #77 on: Fri, 07 November 2025, 04:02:00 »
nm, waitlist
Looks like scam.
-Ray Bradbury
