Author Topic: [In Stock & On Sale] Velocifire AL65 90USD-ish Prebuilt Alu Mechanical Keyboard  (Read 4059 times)
Offline john08099
  • Velocifire MK
  • * Moderator
    • Mechanical keyboards for typers
AL65
Intro
Looking for an affordable, compact keyboard that doesn't skimp on quality? The AL65 has got you covered. Its CNC anodized aluminum body, flexible gasket construction, and hot-swappable switches make it built to last. Plus, with 2.4G, wired, and Bluetooth options, a dedicated knob, and customizable RGB lighting, it's versatile and easy to use. The flex-cut FR4 plate and powerful 4000mAh battery add even more value to this keyboard. With its affordable price, compact size, customizable features, and top-notch build quality, the AL65 is a great choice for users seeking a budget keyboard with a great value.
Photos
Reviews
Specifications
Pre-built: Includes keycaps and switches
Case Material: CNC Aluminum
Surfacing: 150 Mesh Anodized
Layout: 65%  (66 keys + 1 knob)
Mounting Structure: Gasket mount
Keycap profile: Cherry
Keycap material: Doubleshot PBT
Switch: Star flower linear switches, factory lubed, 3 pins
Material of the switch: POM (top case, stem), PA66 (bottom case)
Switch Actuation force: 39±5gf
Switch Bottom out force: 45±5gf
Switch Actuation travel: 1.8±0.2mm
Switch Total travel: 3.6mm±0.2mm
Compatible System: Windows, macOS
RGB: South Facing RGB
Plate: flex cut FR4 Plate
PCB: Hotswappable, flex cut
Battery: 4000mAh
Connectivity: Wired, 2.4GHz Wireless, Bluetooth
Polling rate: 1000Hz (Wired/2.4GHz), 125Hz (Bluetooth)
Weight: 1.65kg (without packaging)
Size: 325.6 x 114 x 31mm
Front height: 22mm
Included
AL65 Keyboard ( with switches & keycaps) *1
USB-A to TYPE-C cable *1
Keycap & Switch Puller *1
2.4G receiver
Dust Cover *1
User Manual *1
Price
94.99USD (Original Price: 99.99USD)
Purchase Now
Please feel free to ask us any questions about the keyboard below! :)
Welcome to join our Discord and follow our Instagram,TikTok for more discussion, latest update and questions! :)
« Last Edit: Tue, 17 December 2024, 21:25:17 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
