Author Topic: The World's First Fluffy, Pettable Custom Mechanical Keyboard – PETBRICK 65  (Read 10448 times)
Offline DryStudio
A keyboard you can actually pet!
Every cat owner has probably experienced the adorable sight of their furry friend lounging on the keyboard, preventing them from getting any work done, right? Now, we bring you a keyboard you can actually pet!
311553-0
100% handmade fluffy outer shell with a plush texture similar to Jellycat toys
We work with a toy factory that has over 20 years of manufacturing experience. Three expert craftsmen, each with 15 years of expertise, meticulously handcraft the short plush shells to achieve a soft, luxurious texture and a rich, three-dimensional effect.
We use premium short-pile fabric that can be gently hand-washed with mild detergent, ensuring easy and convenient cleaning.
This gives the PETBRICK 65 the soft, cozy feel of a stuffed toy, while also ensuring it's easy to maintain without the worry of it getting dirty.
311555-1
From sweet to savory, the removable magnetic shell lets you choose between two styles — hardcore or adorable — so you can switch it up whenever you like
311575-2
The outer fluffy shell is equipped with magnets for effortless removal and can be swapped with other color options.
Simply remove the fluffy outer shell to reveal the mecha-style keyboard beneath, featuring an aluminum CNC frame. This design offers both comfort and flexibility, allowing you to easily switch between two styles, or winter and summer with ease.
The mecha-style of the inner shell is perfect for a variety of desk setups, offering versatility to suit different needs.
311557-3
Tri-mode connectivity
PETBRICK 65 features seamless tri-mode connectivity, offering Wired, Bluetooth and 2.4GHz modes.
With Angry Miao’s technical support, you can seamlessly switch between connection types—just plug in the cable for wired mode or unplug it to switch to Bluetooth.
The 2.4GHz wireless option offers a stable and responsive connection, perfect for a fluid and reliable gaming experience.
311571-4
The sound and feel of a robust, custom mechanical keyboard
The PETBRICK 65 interior is equipped with Angry Miao's patented Leaf Spring mount, featuring an 8-layer construction for optimal sound and feel.
This includes a sandblasted POM plate, specially tuned cotton poron, IXPE 8 switch pad, PET film for improved acoustics, a switch base made from EPDM-mixed PET, and two layers of ultra-low-density EPDM sound-dampening foam.
311559-5311561-6
Eye-catching, high-transparency Crystal Pink Switch, custom-made by DRY STUDIO
Each PETBRICK 65 features a bespoke 'Crystal Pink' developed by DRY STUDIO, crafted with a high-gloss, high-transparency mold that enhances RGB performance to an exceptional level.
The extended PA 12 axis, paired with a highly transparent PC shell, delivers a linear and smooth typing feel.
Together with the soft, flexible Leaf Spring mount, it guarantees a refined and responsive typing experience.
311563-7
Customizable RGB lighting effect
PETBRICK 65 showcases the popular RGB effects loved by AM users. It comes with three pre-set lighting modes, but with AM Master, you can fully customize your own RGB profiles, adjusting everything from brightness to color for a completely personalized lighting experience.
311573-8
Customized high-quality five-sided thermal sublimation keycaps
Both PETBRICK 65 color schemes come with custom cat-themed keycaps. Whether you choose the calico or odd-eyed design, they create a  harmonious visual effect when paired with the fluffy shell.
Placed on your desktop, they offer a unique and soothing presence.
311565-9311567-10
« Last Edit: Tue, 17 December 2024, 21:46:14 by DryStudio »
Offline DryStudio
PETBRICK 65 is now released!
The world's first Fluffy, Pettable Custom Mechanical Keyboard!
- 100% handmade shell
- Leaf Spring mount
- Tri-Mode 2.4G wireless gaming
Product Price: $239 USD
Add a fluffy keyboard to your winter desk that you can pet, just like a furry companion!
https://store.dry---studio.com/products/dry-studio-petbrick-65
311569-0
Offline bevbox
  • beverages boxes
oh i can already see the crust, good thing it looks easily cleanable
Offline phinix
Hair everywhere. Nice.
Offline JackQn
I often sweat a lot, and I'm a little worried that they will get dirty easily. But it looks so cute.
