Author Topic: Where to buy HHKB PRO 2  (Read 7771 times)
Offline codek
« on: Fri, 29 October 2010, 19:07:17 »
I'm looking to buy one of these bad boys.  Just got a couple of model m's off ebay but it's way too big.
I want the smallest keyboard and I do not need a tenkey.
I kinda want the arrows so I was into a maybe japanese version or maybe I'll stick with the US version.
Cheapest I found was about $300 US after tax/shipping.  I'm in Cali.
Is there anything more compact than the HHKB PRO 2?
edit: arrow keys are nice but not a necessity, compact size is a must
« Last Edit: Sat, 30 October 2010, 10:12:04 by codek »
Offline chongyixiong
« Reply #1 on: Fri, 29 October 2010, 22:18:49 »
Quote from: codek;240332
Yes there is:
On a more serious note, 250-300-ish is what you are going to get for the HHKB keyboards.. they don't usually go below 200 even if used.
Offline ironman31
« Reply #2 on: Fri, 29 October 2010, 23:50:51 »
elitekeyboards.com...... which is probably the place you are quoting
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
woody
  •  Guest
« Reply #3 on: Sat, 30 October 2010, 05:30:30 »
Check Cherry G84-4100.
________
colorado dispensaries
« Last Edit: Sat, 05 February 2011, 14:10:34 by woody »
Offline codek
« Reply #4 on: Sat, 30 October 2010, 09:05:25 »
Quote from: ironman31;240387
correct.  I used to live less than 5 miles away from them and they don't have a will call/pick up option.  ghetto.
anywhere I can pick up these badboys used.  I never see it on ebay and there have been a couple here but not too many.  I don't mind used at all.
Offline codek
« Reply #5 on: Sat, 30 October 2010, 09:06:34 »
Quote from: woody;240420
awesome those look nice and they are mechanical.  is there a huge difference in quality between this and the HHKB PRO2 like the HHKB PRO2 VS HHKB LITE or is it just a preference/name brand thing?
Offline codek
« Reply #6 on: Sat, 30 October 2010, 09:07:26 »
Quote from: chongyixiong;240380
Yes there is:
way too many keys
Offline didjamatic
« Reply #7 on: Sat, 30 October 2010, 09:09:29 »
I have a HHKB Lite if that would work for you.
Offline unicomp
« Reply #8 on: Sat, 30 October 2010, 09:30:56 »
There are at least a few boards that are more compact than the HHKB however I don't think that many will retain the arrow keys and most are not good key switches.
The HHKB Lite does have the arrows however it is rubber dome.
I must admit feeling somewhat remorseful after buying my HHKB however this was not because it was not a good purchase, more that I have not really used it enough to justify the cost. I whole-heartedly endorse the HHKB; I have a HHKB Lite also however I only bought this to complement the HHKB.
Offline codek
« Reply #9 on: Sat, 30 October 2010, 10:12:27 »
Quote from: didjamatic;240458
1 or 2? color?
Offline codek
« Reply #10 on: Sat, 30 October 2010, 10:15:28 »
Quote from: unicomp;240464
I'm in the same boat.  Before I came to this forum, I thought I would never spend more than $40 on a keyboard and now I'm considering spending $250 and I've been only here for a day.... scary
What other boards are there?  I'm just looking for mechanical and compact, I can live without the arrow keys
Offline a_fluffy_kitten
« Reply #11 on: Sat, 30 October 2010, 10:24:28 »
Yes there is:
On the Pro version of that keyboard, the left key is Shift and the right key is 0 or 1.
2x Filco Blue Tenkeyless (and boy are they nice)
Offline zefrer
« Reply #12 on: Sat, 30 October 2010, 16:13:47 »
I was thinking the same thing
Offline zefrer
« Reply #13 on: Sun, 31 October 2010, 05:48:28 »
DIP switches are for 60s TV shows and HHKB onry.
woody
  •  Guest
« Reply #14 on: Sun, 31 October 2010, 07:30:14 »
Beware of entering any DIP sh*t.
________
buy silver surfer vaporizer
« Last Edit: Sat, 05 February 2011, 14:11:12 by woody »
