Author Topic: Spherical keycaps for 1800 keyboard?  (Read 19089 times)
Offline Hālian
  • the Protogen
    • Safir Alliance Wiki
« on: Wed, 01 January 2025, 04:48:21 »
I got myself a Royal Kludge RK100 for Christmas, and its upper right corner has exposed the inadequacies of my /dev/tty R2 (IIRC) keycaps for such a layout. That said, has anyone any recommendations for spherical keycaps set that suit this layout? I'm specifically looking for sets that include Row 0 nav cluster caps (Delete, Home, Insert, Page Up, Page Down) and Row 1 caps for the top row of the numpad (Num Lock, /, -, +), or uniprofile sets.
« Last Edit: Wed, 01 January 2025, 04:55:12 by Hālian »
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Spherical keycaps for 1800 keyboard?
« Reply #1 on: Thu, 02 January 2025, 05:34:14 »
/dev/tty R2 was sold as a GB with a main kit & child kits to fill in any layout the base(main) kit did not cover. Sounds like you just have the base kit, but you are in luck since drop is still selling kits from R3. Looks like you just need the Numpad kit https://drop.com/buy/drop-matt3o-devtty-custom-keycap-set?defaultSelectionIds=977204. If there is any keys missing from that you can use the drop down menu to find the kit that has what you need & hopefully they still have it in stock.
Offline Hālian
  • the Protogen
« Reply #2 on: Thu, 02 January 2025, 15:43:29 »
I must be misremembering, then, because I got it off Drop. Must be R3.
