Author Topic: [IC] KCH-Pure Player: XY | Beauty of Evolution  (Read 5031 times)
Offline Jr.Mars
« on: Thu, 02 January 2025, 23:34:31 »
Hi geekhacker, long time no see and happy new year!
Here comes a new dye-sub keycap set: KCH-Pure Player: XY. Manufacutured by Keyreative
Interest Check Form  |  Discord
- Please help me to fill out this form and provide any feedback that you have.
- If you are interested in being a vendor, want to collaborate, feel free to contact me on Discord.
Inspiration & Specs
This is the dark version of GoMaster-Pure Player, if you want to learn more informaiton about Pure Player, it is in-stock on Divinikey
Pure Player:XY is inspired by the works of teenage engineering, specifically the OP-XY Field Portable Synthesizer Workstation.
Just like the design of the workstation, and it being used by mostly producers and musicians to create music, Pure Player:XY was born.
Profile
Cherry Profile
Methods
PBT Dye-Sub
Transparent: ABS UV Printing
Manufacturer
Keyreative
Kittings
Renders
- The transparent keycap samples are not ready, and the renders will be adjusted according to the final samples to ensure consistency with the actual product.
Metal Keycap
This elegant metal artisan features a modular structure, the base and knob.
The base has a bearing installed which helps to achieve the spinning function.
You can easily swap out the standard knob for one of the add-on colours, without the need for any tools.
Color Comparison
- It is photo, not render.
Samples
First round samples arrived, already fed back to the factory, waiting for the second round.
Contact
Discord  |  Instagram
To Do List
1. Vendors
2. Pricing
3. More samples
4. More renders
Offline Jr.Mars
Re: [IC] KCH-Pure Player: XY | Beauty of Evolution
« Reply #1 on: Thu, 02 January 2025, 23:37:26 »
Reserved
Offline keepoto
  • HHKB top for TKL pls
« Reply #2 on: Fri, 03 January 2025, 00:21:18 »
我去麻丝 x 键设局
oh my Mars x Keyreative
オーマイマーズ x キーリアティブ
Oh mon Dieu Mars x Keyreative
о мой Марс x Keyreative
ôi trời ơi sao Hỏa x Keyreative
오 마이 마스 x 키리티브
ախ իմ Mars x Keyreative
अहो मम मंगल x Keyreative
