Author Topic: [Pre-Order] System_65 | Pre-order and save 10%, ends Jan 31  (Read 1691 times)
Offline mozaic
    • [IG] Mozaic
« on: Sun, 12 January 2025, 12:25:10 »
Pre-order is live until January 31
Link to pre-order page: https://shop.mozaic.dev/products/system_65
For updates and behind the scenes, follow on Instagram @mozaic.dev
Sign up to the mailing list to receive an additional bonus discount on some add-ons
Prototype albums: Prototype 1 (2022), Prototype 2 (2024)
Before you continue, note this is a summarized version of the details.
Read the full details here: https://shop.mozaic.dev/pages/system_65-interest-check
Table of Contents
1 - Vendor and Pricing
2 - Dates: Pre-order, In-stock, Shipping
3 - What's Included
4 - Add-ons
5 - Variants
6 - Details
7 - Specifications
8 - Prototypes
Vendor: Mozaic, https://shop.mozaic.dev/collections/system_65
Pre-order: $346.5 USD
In-stock: $385 USD
Pre-order now and Save 10% off in-stock pricing.
Pre-order: Ends January 31, 2025
In-stock: Starting in February
Shipping: Begins in February
Vendor: Mozaic
3 - What's Included
- Top
- Bottom
- Plate
- Accent Weight
- Badge
- PCB (+ Daughterboard, JST)
- SKUF (feet)
- Screws (torx)
- Magnets (pre-installed)
- Custom Packaging
4 - Add-ons
PCBs: Hotswap (included), Solder
Plates: Aluminum (included), Polycarbonate, FR-4, Acrylic (2-for-1)
Accent Weight: PVD Black, PVD Blue, Matte Black, Electropolish, Multicolor
Badge (blank, no engraving): PVD Black, PVD Blue, Copper, Electropolish, Multicolor
5 - Variants
Variant| Azure Odyssey| Imperial White|Triple Black
Top| Silver| White (E-coat)| Black
Bottom| Silver| White (E-coat)| Black
Accent Weight| Blue PVD| Black PVD| Black PVD
Badge| Blue PVD| Black PVD| Black PVD
6 - Details
- Front facing weight, attached via magnets
- Badge on the bottom, attached via magnets
- Raised back, similar to Pro HG
- PCB and plate support all layout options
- PCB hotswap and solderable, supports QMK and VIA
- Plate options | Aluminum, PC, or FR-4
7 - Specifications
Layout: 65% | split backspace, split left shift, ANSI/ISO enter, 6.25/7u spacebar
Mounting: Top mount
Typing Angle: 7 degrees
Front Height (Adjusted): 19.4 mm
Weight (Unbuilt): ~1.22 kg
8 - Prototypes (Renders represent final design)
v1 (Album)
- Screws for accent weight
- No badge
- No Hotswap support
v2 (Album)
- Magnets for accent weight
- Added a badge
- Adjusted case design to support hotswap PCB
- Reduced screw count for assembly
Final (Shown in renders)
- Changed magnets sizing, position, count, and adhesive
- Fixed case design clearance for hotswap support
- Adjusted plate edge to reduce case contact
- Added small foam strips to prevent bottom-out contact
