Author Topic: [GB] ASCII-F : 65TK || Plateless Top Mount - GB OVER  (Read 36582 times)
Offline enomooshiki
« on: Mon, 13 January 2025, 01:01:20 »
ASCII-F
PCB Top Mount 65TK
When I picked up an old WYSE ASCII off Craigslist, it reminded me of a keyboard layout I desired a few years ago: a full 65% keyboard with a complete numpad that includes arrow keys, a navigation cluster (PgUp, PgDn, Home, End), and a 2u 0 (zero) key on the numpad.
Taking design cues from some of my favorite keyboards, I kept the bezel quite thin and the overall profile simple and slim.
The Plateless Top Mount provides a soft and 'bouncy' typing experience without being flexible. If soldering plateless is a daunting task for you, we will have options available for hotswap PCBs and plates.
Group Buy starts on January 13th, 2025 and ends on March 1st, 2025
Estimated fulfillment date - May 2025
- enomooshiKey IG
- zenclack IG
- Zenclack Discord
0. CONTENTS
  • DETAILS
  • STATUS & UPDATES
  • VENDORS & PRICING
  • RENDERS
  • PHOTOS
  • OTHER MEDIA
  • SPECIAL THANKS
1. DETAILS
  • Typing angle 7.0°
  • Front Height : 17.8mm (after cherry lip), 20mm (before cherry lip)
  • Mounting Method : Plateless Top Mount
  • PCB : Designed by Freather with Universal USB-C daughteboard - configurable with QMK/VIA
  • Solder PCB Layout Option
  • Hotswap PCB Layout Option
  • Base Kit
    - Top Case
    - Bottom Case
    - Daughter Board with JST Cable
    - Solder PCB
    - Carry Case
    - Microfiber Towel
    - Case screws
    - DB screws
    - Top Mount screws
  • Case Options
    - Alu Top + Alu Bottom
    - Alu Top + Brass Bottom
    - Alu Top + Copper Bottom (Limited Edition maybe)
  • Colors For Alu Top + Alu Bottom
    - Black Top + Silver Bottom
    - E-Beige Top + Silver Bottom
    - E-Beige Top + Black Bottom
    - E-White Top + Black Bottom
    - Silver Top + Black Bottom
  • Colors For Alu Top + Brass Bottom/Copper Bottom
    - E-Beige
    - E-White
    - Black
    - Silver
  • Weight Unbuilt
    - Alu Top + Alu Bottom = 1.34kg
    - Alu Top + Brass Bottom = 3.46kg
  • Plate Options for Hotswap PCB
    - PC
    - FR-4
    - PP
    - Alu
  • Optional Alu Wrist Rest : matching anodization or e-coat with top case
  • Indicator LED for Caps Lock and Num Lock keys
2. Status & Updates
  • Group Buy Started
3. Vendors & Pricing
  • Vendors
    -NA: Zenclack
    -Asia/AUS: Zenclack , fulfillment for Korea to be out of Busan
    -UK&EU: Prototypist
    -China : Keyspensory/Freather
  • Price
    - Alu Top + Alu Bottom = $250 (with solder PCB) $280 (with Hotswap PCB + plate)
    - Alu Top + Brass Bottom = $450 (with solder PCB) $480 (with Hotswap PCB + plate)
    - Alu Top + Copper bottom (10 units from Zenclack, 5 units for Prototypist, 5 units for Freather's Studio) = $500 (with solder PCB) $530 (with Hotswap PCB + plate)
    - Alu Wrist Rest (color matched to top case) = $50
    - Extra Solder PCB = $40
    - Extra Hotswap PCB = $45
    - Plates = $25
4. Renders
Actual coating and anodizing may look a bit different from these renders. Please use these renderings as a reference.
renders by mur1_fat
Beige Coating Top + Brass Bottom + GMK Hiney Beige
White Coating Top + Black Ano Bottom + GMK WoB
Silver Ano Top + Brass Bottom + GMK Evil Eye
Black Ano Top + Silver Ano Bottom + GMK ASCII
4 Options for Brass Bottom
5 Options for Alu Bottom
Beige Coating Top + Brass Bottom + GMK Blue Alert R2 (special render by Steven Olver)
5. Photos
Proto V1 with matching wrist rest
Proto V2 with GMK WoB Hangul
Proto V2 with GMK DMG
7. OTHER MEDIA
Build and typing test by Alexotos
Build and typing test by Xinxinwong
Typing test with Ergo Clear, Plateless, Alu Top and Bottom by TimKeyLess
Typing test with Cherry MX Reds, Plateless, Alu Top, Brass Bottom by LightningKeyboards
Typing test with Gateron Cream Soda, Plateless, Alu Top and Bottom by Marshmellohs
Typing test with Gateron Cream Soda, Plateless, Alu Top and Bottom by TylerKeyboard
Typing test with Cherry MX Black, Plateless, Alu Top and Bottom by ExtraPriusPlease
Review by Keybored
Build and type test with Gateron Summertime v2, PP Plate, Alu Top and Bottom by StaceySmash
Typing test with HMX Jammy, Plateless, Alu Top and Bottom
Typing test with BSUN BCP, Alu Plate, Hotswap PCB, Alu Top and Bottom
8. SPECIAL THANKS
  • My lovely wife, for putting up with my numerous hobbies
  • Tofumania, for putting my vision into Fusion 360
  • Glendel/Zenclack, for having faith in ASCII-F
  • Freather, for coming in clutch with PCB design
  • TimKeyLess, for getting me into this crazy hobby
  • Gok, for letting me use his IC page style
  • Lightning & Manoli, for helping me through IC creation
Thank you very much.
GeekHack Banner Support
If you would like to support ASCII-F, consider adding the signature below to your profile
Code: [Select]
[url=https://geekhack.org/index.php?topic=124310.0][img width=384 height=120]https://i.imgur.com/jYgUgbS.png[/img][/url]
« Last Edit: Mon, 03 March 2025, 13:40:43 by enomooshiki »
Offline enomooshiki
Re: [GB] ASCII-F : 65TK || Plateless Top Mount - Jan 13,2025 until Mar 1, 2025
« Reply #1 on: Mon, 13 January 2025, 01:01:29 »
RESERVED
« Reply #2 on: Mon, 13 January 2025, 23:37:58 »
Approved :thumb:
Offline cqdemal
« Reply #3 on: Tue, 14 January 2025, 04:36:33 »
I know saying this now is way too late but I'd kill for a southpaw version of this.
Offline futurecrime
  • Get Zooted
« Reply #4 on: Tue, 14 January 2025, 08:42:32 »
Looks great with DMG. The lines on the side echo the speaker on the GameBoy. Very nice.
Offline bigmaxnonions
« Reply #5 on: Tue, 14 January 2025, 09:29:58 »
What is the limited edition drop for Zenclack? Is it like a special edition color or is there like a limited in stock drop while supplies last?
Offline enomooshiki
« Reply #6 on: Tue, 14 January 2025, 11:28:47 »
maybe R2?
Offline enomooshiki
« Reply #7 on: Tue, 14 January 2025, 11:28:56 »
Thank you!
Offline enomooshiki
« Reply #8 on: Tue, 14 January 2025, 11:29:27 »
Limited Edition (LE) is full copper bottom. Limited to 10 units for Zenclack, 5 units for Prototypist!
Offline ObsessiveCaps
« Reply #9 on: Tue, 14 January 2025, 12:19:57 »
Congrats on entering GB! Had to go for a Limited Edition. Tough choice on colorway, but I'm eager for some beautiful black on copper action.  :thumb:
Offline Seoeunmonster
  • thetypinglife
« Reply #10 on: Wed, 15 January 2025, 07:32:40 »
Congrats for GB. Looks amazing with GMK DMG. And platelss top mount would be very interesting!
Want to go limited edition, when I can afford it XD.
Offline enomooshiki
« Reply #11 on: Thu, 16 January 2025, 00:31:14 »
Thank you!!!Black on Copper/Brass will be very sexy
plateless top mount = GOAT
Offline enomooshiki
« Reply #12 on: Fri, 24 January 2025, 14:04:13 »
Added a new typing test video from Marshmellohs!
Offline pixelpusher
« Reply #13 on: Sat, 25 January 2025, 14:29:19 »
Are there any photos or videos of the e-beige color with popular keysets (perhaps 9009 or blue alert) for color reference?
Offline enomooshiki
« Reply #14 on: Sat, 25 January 2025, 16:01:11 »
LightningKeyboard did a typing video and took some photos with the E-beige prototype recently.
Offline enomooshiki
« Reply #15 on: Tue, 04 February 2025, 16:50:30 »
StaceySmash did a build/typing video!
Offline enomooshiki
« Reply #16 on: Tue, 18 February 2025, 15:16:52 »
Updated with Build & Type Test videos from Xinxinwong and Alexotos
Offline enomooshiki
TODAY IS THE LAST DAY TO JOIN THE GROUP BUY!
Offline enomooshiki
Re: [GB] ASCII-F : 65TK || Plateless Top Mount - GB OVER
« Reply #18 on: Mon, 03 March 2025, 13:41:08 »
GB ENDED!
Thank you everyone who joined the GB!
Future updates will be posted in the reserved section
