Author Topic: Is the RK61 good? (or worth its money)  (Read 4987 times)
Offline SarmasJr
« on: Sun, 19 January 2025, 11:00:01 »
So, I was looking for a really cheap 60% keyboard, with wireless being an option. I got blasted by the Royal Kludge rk61. There is some duality between the reviews Im reading. One half says its great for the money and really worth it, while the other half says it shows too many problems and no one should ever buy it. Another redditor pointed me to this site. So I ask you, should I buy it, or should I buy something else? Thanks!
Requirements:
60%
cheap (60 dollars tops)
Wireless option
comes in white colour
Offline Pignity
Re: Is the RK61 good? (or worth its money)
« Reply #1 on: Wed, 29 January 2025, 11:06:42 »
no, maybe consider lucky65 if you are ok with building it yourself
