Author Topic: Low-profile keyboard recommendation  (Read 3979 times)
Offline thieladhinami
« on: Sun, 19 January 2025, 15:14:50 »
Hello!
I ordered a Wooting 80 HE keyboard for myself, and unfortunately, during the transition period until I receive it, I need another keyboard.
Since I don’t want to buy a keyboard unnecessarily, I would like to choose one that I will continue to use later, even with another computer.
What’s important is that it should have an ISO layout, be between 70% and TKL size, and be low-profile. I’d also appreciate it if it had some sort of backlighting, but that’s not really a must.
I really like laptop keyboards. I’m writing this message from a Razer Blade laptop, and I really like its keyboard as well. I also really like the keyboards offered by Apple, so I’m looking for something similar to these.
My budget is a maximum of 110 - 120 euros.
What would you choose if you were in my place?
Thank you very much!
Offline wjrii
Re: Low-profile keyboard recommendation
« Reply #1 on: Sun, 19 January 2025, 22:34:29 »
Certainly at least check out the various flavors of the Keychron K3.
