Author Topic: SOLVED: I need Realforce keycap  (Read 49284 times)
Offline phinix
« on: Sun, 19 January 2025, 17:51:21 »
SOLVED, got one:)
Do you guys have those extra keycaps that were added to Realforce keyboards in the past?
I cannot remember what they were - CTRL and Capslock for a swap?
I have a broken keycap - CTRL which I need to replace.
These ones
311919-0
« Last Edit: Tue, 25 November 2025, 05:13:19 by phinix »
Offline jyap
Re: I need Realforce keycap
« Reply #1 on: Wed, 07 May 2025, 00:00:06 »
Buy the R3 modifiers set.
In stock these days and work fine.
Offline phinix
« Reply #2 on: Wed, 07 May 2025, 03:30:48 »
Link please
Offline jyap
« Reply #3 on: Sat, 10 May 2025, 01:03:31 »
Link please
https://mechanicalkeyboards.com/products/topre-realforce-r3-keycap-set?variant=50720340640044
You'll want to select "Text Modifiers".
I bought the Alpha set for my R2, the only difference is that that you only have these colors to choose from and the keycaps don't have the same legend prints on the side. The R3 sets however include keys which have blank legends so I use those ones on my R2.
Offline phinix
« Reply #4 on: Tue, 13 May 2025, 03:42:33 »
Link please
Thanks.
I see those are white, plus caps I need are from R1 keyboard, which are light grey. But yeah, this is good for buying extra caps for R3.
I may actually buy R3, as wanted good new Realforce, I wish they make grey mods version though.
Offline Tune Lab
« Reply #5 on: Wed, 15 October 2025, 03:34:00 »
Does anyone know where I can get grey keycaps for the Realforce?
