Author Topic: Gateron Green Apple Switch Review  (Read 9215 times)
Offline ThereminGoat
« on: Sun, 26 January 2025, 10:34:02 »
Hey all,
Yes, I realize that the Gateron Green Apple switches are also Gateron-made tactiles just like the Sillyworks X Gateron Type R switches I reviewed on the last one. Well they aren't the exact same tactiles, just both tactiles from Gateron. I swear there is some reason for this, even if it's not a good one.
Website: https://www.theremingoat.com/
Article: https://www.theremingoat.com/blog/gateron-green-apple-switch-review
Scorecard Repository: https://github.com/ThereminGoat/switch-scores
Force Curve Repository: https://github.com/ThereminGoat/force-curves
Patreon: https://www.patreon.com/theremingoat
As always, thank you all for the continued readership and support week in and out. Hopefully the fruits of what I share in the background section of this review bear out sooner than not, though only time can tell. I should probably get back to work on that now since I started talking about it...
Cheers,
Goat
