Author Topic: [IC] MW Enka | The Sound of Emotions  (Read 11698 times)
Offline balance
« on: Mon, 27 January 2025, 16:40:24 »
IC Form
Discord Server
Hello everyone! This is a set inspired by a Japanese music genre called Enka which is a form of sentimental ballad music. As 14th February is approaching and is all about love, I decided to mix the themes and I've got this combination of colors.
This set uses RAL design colors.
Renders(done by me)
Base Kit
Numpad Kit
Alphas Kit
Spacebar Kit
International Kit
Board Renders
TGR JANE BY YUKTSI
TX 65 BY TX KEYBOARD
TGR ALICE BY YUKTSI
Color comparison
IC Form
Discord Server
If you are interested, please fill the form above and join the server for more updates.
Thank you for your attention!
« Last Edit: Sun, 11 May 2025, 10:20:18 by balance »
Offline balance
Re: [IC] MW Enka | The Sound of Emotions
« Reply #1 on: Mon, 27 January 2025, 16:49:16 »
reserved
Offline kentdo10
« Reply #2 on: Wed, 29 January 2025, 01:14:02 »
I like this <3
Offline bibione
« Reply #3 on: Thu, 30 January 2025, 09:11:23 »
Spacebar kit is missing a red 1U
Offline balance
« Reply #4 on: Wed, 12 February 2025, 07:24:08 »
Small kitting update!
-Added an International Kit
Offline konstantin
  • Formerly constexpr
« Reply #5 on: Fri, 14 February 2025, 10:32:35 »
Quaternary (top-right) sublegends are wrong on some of the number row keys and are also missing altogether from some of the punctuation keys. I suggest double-checking all of the sublegends for accuracy.
Offline balance
« Reply #6 on: Thu, 20 February 2025, 12:03:14 »
Thanks for the comment. The render is now changed.
Offline konstantin
« Reply #7 on: Thu, 20 February 2025, 12:18:00 »
Looks good :thumb: The “を” should also be large, but that's very minor, the manu will have the correct legend either way.
You may also want to consider moving the R1 End, PgDn keys from base to the numpad kit, since those are for 1800/CP/96-key compat and are only ever used together with numpad keys. Including a “=” key in the numpad kit might also be worthwhile.
« Last Edit: Thu, 20 February 2025, 12:23:34 by konstantin »
Offline balance
« Reply #8 on: Wed, 12 March 2025, 14:21:54 »
The kitting is made according to their default kitting so I need to check with them if I can change.
Offline balance
« Reply #9 on: Sun, 11 May 2025, 10:23:54 »
Update!
- 2 keys from the Base Kit moved to the Numpad Kit
- Waiting for another sample round of the keycaps!
