Author Topic: [IC] GMK CYL Highlight (Hi Leicht) | Poll to decide modifier legend preference  (Read 25842 times)
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK CYL Highlight (Hi Leicht) | New Renders, Base Kit Update, ?Novelty
« Reply #50 on: Sat, 15 February 2025, 14:58:50 »
I’m good w any variant color wise
Fully support you cutting out anything possible to keep the base kit price at 135 or less as MOQ is hard these days. I’ve used double zero before but would rather have this be made than a 140$ base kit that gets canceled like some other sets recently.
« Reply #51 on: Sat, 15 February 2025, 17:40:09 »
I'd buy full base kit versions of each of these colors if I could. Especially the Magenta(?) used on the Caps Lock and Left Shift
Offline AMZ
« Reply #52 on: Sun, 16 February 2025, 06:04:43 »
I did not liked the red color actually it is better to be without red color
Offline Its_Skullhead
« Reply #53 on: Mon, 17 February 2025, 02:50:15 »
I love the changes to the base kit so far, however is there any chance one of the variations of F/J could be Scooped? Having both options of scoop. And bar is a staple I feel that should be considered. Please consider scoop lovers :(.
Offline Bobatype
    • Discord ID: BobaSweatandTears#1659
« Reply #54 on: Mon, 17 February 2025, 03:58:40 »
Novelkeys has kindly agreed to be the US vendor
:thumb:
Perhaps there might be a possibility in the future, but I'd like to see how these sample turns out first. Yes, I would love to a super neon pink keycap set if there's interest. For this set, I'm calling the pink on the modifiers 'Magenta' and the pink on the alphas 'Fuchsia'
Appreciate your opinion/thoughts! As I don't have samples yet, please note that my current renders are not potentially the most accurate, and the 'red' has since been changed to RAL 2005 (the same as GMK Flare) since I was concerned it would be a bit too difficult for 'red' match the fluorescent energy of the other colors. In fact a lot more 'orange' in nature, and not red. I'm calling it 'orange-red', but I'll try to play with some renders and see if it really adds much to the set. The original concept had alphas primarily only orange (with yellow homing keys), which is why the 'red' was initially used; to help introduce a bit of visual variety with the bottom row modifiers. Now that the alphas are a mix of orange and fuchsia, it's purpose is less meaningful visually. So I'll have a play around to see if the 'red' is that important...
For now, the yellow F/J will come as both scooped and barred homing keys, whereas the fuchsia F & orange J will come only as barred. Trying to keep the base kitting price in mind atm.
Offline cryoverkiltmilk
    • My Tumblr
« Reply #55 on: Tue, 18 February 2025, 17:13:54 »
Yeah, I like this.
Like it even more if there was ortho support.
Offline culain
« Reply #56 on: Wed, 19 February 2025, 15:16:35 »
Oh good lord I want this in my life!  I want this so badly! Amazing set, bravo!
Offline bobbynoee
« Reply #57 on: Sat, 22 February 2025, 17:12:05 »
Super excited for this one!!!
Offline kein_mark
« Reply #58 on: Tue, 25 February 2025, 03:44:11 »
Super excited as well! Do you have an idea about the timeline of this project?
Offline örange_stone
  • No fancy life But fancy keyboard
« Reply #59 on: Thu, 27 February 2025, 20:24:23 »
Wow, this set is so unique. Probably too many colors for me, but I would use it as a highlight for my WOB set and put it together. I think they will create a cool effect together. :p
Offline Bobatype
<3
Rough timeline is late Q2 or early Q3.
Yeah, I like this.
Going to be honest that it's frankly quite difficult to do ortho/40s specific child kits in the current market. It's not likely without strong vendor support. I can potentially provide some physical layout coverage for 1u modifiers by covering for double macro column (XT-layout) in the add-on or novelty kit. It's an approach I'm trying in the Art Deco novelty kit for GMK Black and Gold, a groupbuy I'm currently I'm running at the moment.
Due to this set having a more varied pattern of colors, it's a little bit harder to predict how this would look on an ortho board though.
Yeah I think you could definitely remix some of these caps with WoB for a unique look.
I've been informed by GMK that samples should be arriving in the next week or so :)
Regarding the novelty kit, I'll include the R1 Sticky Note, R1 'Hi' and R4 'cool S' (in both 1u and 1.25u), but for the other novelties, I'm still figuring it out.
- ? More sticky notes on R1 in each color; or doing them as relegendables and uv-printing the sticky note graphic under the relegendable cap
- ? 'Esc' on R1 with all letters in the same font style as cool S
- Perhaps I'll continue to lean into the doodle aesthetic to keep it fun, like a variety of emoji style expressions for each row. Or just some random doodles like stars, arrows, scribbles etc.
- Still not sure yet what to do for Enter novelty keys... perhaps 'Highlight' in outline bubble style font, or a scribble or something... open to suggestions/ideas
Offline mr_foggy
  • neue = nope
icon only mods was better
Offline Bobatype
I hear you. I typically prefer my modifier legends icon style (it varies based on overall design/theme ofc), as it makes it look less 'busy', so I'm open to switching back to it (after all, the bottom row and nav-keys are still 'text' only). I note that GMK Handarbeit and GMK Panels had icon legends, whilst DCS Windbreaker had Icon+Text legends.
Conceptually, I felt that 'text-only' modifiers fit the theme best, but it's actually my least preferred option based off renders done thus far.
This is an old base kit render with the icon modifiers:
I'll try and do some quick renders with icon legends for visualisation comparison.
With the silly/fun novelties I have in mind, I'm feeling that icon legends will perhaps fit better overall.
Offline FoxandFoundry
I disagree. The classic Icon + Text is superior.
Edit: After staring at the set for a while, I could go either way. Perhaps there should be a vote?
« Last Edit: Fri, 21 March 2025, 02:51:47 by FoxandFoundry »
Offline Thompywhompy
I prefer text + icon or text only. I think that fits more into the theme
Offline codecoffeecode
  • refill needed by Glenn Jones
Very much looking forward to this! GLWIC!
Offline Bobatype
Modifier legends Comparisons:
Several renders below comparing different modifier legends.
Icon legends vs text+icon legends (current iteration) and text only legends.
Open to thoughts. Here's a poll: https://strawpoll.com/XOgOVE4m2n3
Please vote.
You can select multiple options if you're not set on just one option.
Paragon
Phoenix
M-60A
POLL LINK: https://strawpoll.com/XOgOVE4m2n3
In other news, I have received samples, and whilst some colors are great (yellow and pink being the best), some aren't quite there yet, so the engineers at GMK have been provided my feedback.
« Last Edit: Fri, 28 March 2025, 02:48:14 by Bobatype »
Offline bigmaxnonions
Isn't the idea of handarbeit to encourage and teach proper typing techniques? To me it makes the most sense to have text + icon because its the easiest for someone who is learning how to type to understand.
Offline Bobatype
I'm not sure that argument makes much sense to me.
The OG G81-3000HBD Handarbeit has mostly icon legend modifiers:
Interestingly though, the ISO enter is text-only but in all uppercase, whereas the pg up, pg dn, scroll lock, and num lock is text+icon.
GMK Handarbeit itself is icon legends.
Anyways I appreciate everyone voting in the public poll.
(if MOQ wasn't a concern, I would have liked to see if a German text mods kit was viable (essentially a gutted version of nopunin10did's GMK Prussian Blue's child kit))
« Last Edit: Sat, 29 March 2025, 18:41:20 by Bobatype »
Offline Punkypj
Uk iso possible?
Offline Guuuf
I’ve set myself a reminder for GMK Highlight so I can check in on the progress from time to time. Looks like your project isn’t on ice after all, great to see! I can’t wait.
Have you found a European vendor to support your project yet? Maybe Oblotzky or EloquentClicks? It would be amazing if an International Kit became a reality, too. If there’s an Int Kit, I’d buy two sets with it. Promise!
And I’d definitely welcome R5. I feel like there aren’t enough R5 sets, but I guess not everyone sees it that way. I’d still buy it with R4 though.
Not a big deal, but I’d prefer Icon+Text mods, though I’d be fine with Text mods as well. Not sure if I mentioned that before.
Keep it up, your set rocks so much!
Born 330 ppm, anonymer Schokoladiker, keyboard enthusiast, age150ramnv8nfx2w740jcqrcewzr88d5xymvqv9asjeamvv0pnad3xqyg8qpt[color]
Offline ArchDill
This set gives me so much anxiety  :eek:
I love it.
Let’s see those samples
Offline iwobobul
If you replace dark color legends this will be a goated set IMO. I know highlighters in your inspo had black text on them, but IMO neon legends would work so much better on this.
I think Dark legends are both more readable and help make the neon colors pop more due to the contrast. Just look at GMK Flare
Offline nico.psd
This might be the first kit to interest me since returning to the community, this is riduclously bright!
