Author Topic: Need a 60% hot-swap PCB & plate in Europe – considering GK61 as a donor for Tofu  (Read 17109 times)
Offline mmfood__
Hey everyone,
I'm currently trying to build a 60% custom keyboard with a Tofu60 Redux case, but I'm struggling to find a compatible hot-swap PCB and plate in Germany/Europe. Most common options (DZ60RGB V2, BM60, Nordic60, etc.) seem to be out of stock or unavailable from EU-based stores.
Since getting a standalone PCB is proving difficult, I'm considering buying an Epomaker GK61 from Amazon and removing its PCB & plate to use them inside the Tofu60 Redux. However, I'm unsure if the PCB will fit properly, especially in terms of USB-C port alignment, mounting points, and general compatibility.
Has anyone tried this before? Would the GK61 PCB & plate work inside the Tofu60 Redux?
If not, are there any other budget-friendly 60% keyboards with a hot-swap PCB that could work as a donor for this build?
Any insights would be greatly appreciated! Thanks in advance.
Offline fpazos
Why just not buy some pcb from Aliexpress? I think it'll be the best cost / quality option
