Author Topic: [IC] iP-65%  (Read 5463 times)
Offline njcxqqy
  • Less is a bore
[IC] iP-65%
« on: Fri, 14 February 2025, 02:25:03 »
Hello! This is Darwin from CastleBravo Studio.
As the next gernation, we’re excited to unveil a preview of our upcoming product. We are set to meet you officially after the holiday season.
As a continuation of the iF series, this project began its journey back in 2023. After countless refinements and explorations of innovative designs and technologies, we’re proud to present a creation that seamlessly blends graceful curves with craftsmanship.
312281-0
Inspiration & Creativity
When completing our previous design, an ambitious idea took root — inspired by architecture, particularly the elegant lines and layered aesthetics of traditional Chinese rooftops. These architectural forms embody a harmonious blend of beauty and functionality, a balance we sought to capture in our favorite 65% compact keyboard design.
Design Elements: A Dialogue of Inspiration
1. Roof Curves: The Harmony of Aesthetics and Functionality
The roof of traditional Chinese architecture is not only a work of art but also a manifestation of functionality. From no curves to partial arcs, from large curves to gentle slopes, each transformation tells the story of the harmony between structure and necessity. The application of the "fastest water drainage line" principle allows rainwater to flow smoothly, preventing accumulation. Likewise, we use flowing curves to blend aesthetic and functional balance, infusing Eastern architectural philosophy into modern design.
312283-1312285-2
2. Layered Grilles: A Tribute to Craftsmanship
Supporting the elegant curves is the clearly defined grille structure, a reimagining of the ancient architectural purlin beams. Just as purlins supported the roof, our grille holds the design in place. Countless intersecting lines form a rhythmic symphony between the frames, steady yet graceful, making the keyboard a beautiful fusion of function and art.
312287-3312289-4
3. Curved Frame: A Seamless Transition of Flow and Serenity
The midframe, like the spine of a building, is the soul of the design. Inspired by the graceful curves of traditional Chinese ceramics, from the delicate neck to the rounded body, it pays homage to both softness and balance. The arc on the back seamlessly transitions into the edges of the midframe, like a spring breeze gently sweeping through the mountains, warm and full of life.
312291-5312293-6
Dynamic Curves, Layered Stories,
All in pursuit of the perfect fusion of beauty and function.
This is just the beginning — a prologue to the stories we are eager to share.
Our prototypes will debut after the holiday season, showcasing our journey of innovation and aesthetic exploration.
Stay tuned for more tales of creativity yet to be revealed.
Offline DirtyGingy
Re: [IC] iP-65%
« Reply #1 on: Fri, 14 February 2025, 06:32:44 »
It doesn't seem like a bad design, but could we please see some full photos/renders?
Offline AerosolFNTM
Re: [IC] iP-65%
« Reply #2 on: Fri, 14 February 2025, 19:22:27 »
Definitely like the inspiration of the design but need to see more before really getting on board.
Offline CONIN
Re: [IC] iP-65%
« Reply #3 on: Sat, 15 February 2025, 14:03:08 »
As the next gernation...
I'm not an English spoken person, may I kindly ask what "gernation" means?, thank a lot in advance.
Offline njcxqqy
  • Less is a bore
Re: [IC] iP-65%
« Reply #4 on: Sat, 15 February 2025, 14:46:53 »
gerenation, i made a mistake in typing it
Offline njcxqqy
  • Less is a bore
Re: [IC] iP-65%
« Reply #5 on: Sat, 15 February 2025, 14:48:30 »
Thank you for your support, we are working on the prototype, we will bring new update to this design soon.
