Author Topic: [6gv2]  (Read 21622 times)
Offline zhuak1
[6gv2]
« on: Sun, 31 October 2010, 19:30:16 »
Guys.  I play cs and i have this keyboard but it seems that he lags! im using USB.. should i use ps2?
Offline Arc'xer
[6gv2]
« Reply #1 on: Sun, 31 October 2010, 19:41:19 »
If you want to use PS/2 go right ahead it's an option either way to have a direct interruption of the CPU.
But if it lags then it should be another problem and not a port issue. It's the game's fault, unless the keyboard is damaged in some way.
Offline zhuak1
[6gv2]
« Reply #2 on: Sun, 31 October 2010, 19:53:55 »
i dont think its a keyboard problem but something is wrong, im not so fast pressing the buttons or something like that, "straf'ing" in 1.6 like pressing A and D too fast the key seems to "LAG"!
Offline Rajagra
[6gv2]
« Reply #3 on: Sun, 31 October 2010, 21:34:54 »
Use Aqua's Key Test. You should be able to tell from this if your keyboard is responding as it should.
If PS/2 is noticably faster than USB connection, you probably have a faulty peripheral or controller on the way out.
Offline zhuak1
[6gv2]
« Reply #4 on: Sun, 31 October 2010, 21:39:51 »
Didnt try out ps2 but i thing theres a little delay on this.
And rajagra, when i download the file it doesnt open an .exe, its .exe-t file cant open it.
yes, maybe its my MoBo or usb ports problem. Because i cant get stable 500hz on my mouse, it gives me 450-550 and sometimes 1500 or 1900 or wtv. cant get stable values from 499 500 like i've had before i get this new PC (P5Q PRO TURBO mobo).
I've an 1.1 Zowie by the way
Offline zhuak1
[6gv2]
« Reply #5 on: Sun, 31 October 2010, 21:42:37 »
Ok, i've downloaded the test but how can i see if i have a delay? Btw, my "Win" left to space key isnt working
Offline Rajagra
[6gv2]
« Reply #6 on: Sun, 31 October 2010, 22:18:19 »
Assuming you have a fairly recent gaming PC, the key test program should respond instantly as you press and release each key. Hammer away on them and see if it feels right. You shouldn't sense any lag. I'm on an old Athlon 64X2 4200+ machine right now and it shows no lag.
And the 6GV2 doesn't have a left Windows key. You won't catch me there! :smile:
Offline aegrotatio
[6gv2]
« Reply #7 on: Sun, 31 October 2010, 22:23:15 »
The only lag I've noticed is when I moved from CRT monitors to LCD monitors.
Oh, and only wireless keyboards have lag.  USB and PS/2 are just right.  Check your settings or get a new 'pooter.
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
Offline Rajagra
[6gv2]
« Reply #8 on: Sun, 31 October 2010, 23:23:34 »
Maybe try disabling legacy usb support in the BIOS?
How are you testing the speed? dx_mouse_timer_dialog.exe seems good. Available here for example.
Offline Zen
[6gv2]
« Reply #9 on: Mon, 01 November 2010, 12:15:16 »
I have the same keyboard and also play cs :
YES, you should use PS/2, it does "lag" over USB .
ALL keyboards "lag" over USB, most people probably won't notice
but gamers who are used to the smooth "gliding" feel will .
« Last Edit: Mon, 01 November 2010, 12:17:17 by Zen »
Offline Fwiffo
[6gv2]
« Reply #10 on: Mon, 01 November 2010, 12:58:25 »
A keyboard hooked up through PS/2 will have more air and presence with fuller bass and more dynamic mids.
You can call me... Keyboard Otaku... or not quite...
Offline Zen
[6gv2]
« Reply #11 on: Mon, 01 November 2010, 13:04:02 »
"Lag" is probably not the right word to use..
It's like the game reacts instantly/simultaneously to any input over PS/2,
making the mouse and keyboard kinda "disappear", over USB you kinda
notice (or "feel") that millisecond where nothing happens.
Not all people notice it, a bit like how some people simply can't see or feel any difference between a CRT-monitor
running 60Hz and one running 100+ ..
Only if the cables have been cryo-frozen and coated with linseed-oil :)
« Last Edit: Mon, 01 November 2010, 13:07:23 by Zen »
Offline zhuak1
[6gv2]
« Reply #12 on: Mon, 01 November 2010, 14:27:39 »
So.. i should use Ps2 guys?
Maybe its just placebo or ..not. And about the aqua key test.. cant understand. About mouse HZ, i use mouse rate checker and i dont get stable 500hz.
Offline Fwiffo
[6gv2]
« Reply #13 on: Mon, 01 November 2010, 14:58:46 »
I don't think anyone has demonstrated that they can actually tell the difference in responsiveness between USB and PS/2, which is why I made the comparison to audiophile nonsense. I don't even know if anyone has demonstrated that they can even measure the difference in a real-world situation (i.e. a computer with an operating system).
It would easy to do a double-blind ABX test. Hook up two identical keyboards, one though USB, the other through PS/2 and have someone try to identify which is which without looking at the connections.
Quote from: zhuak1;241191
It's almost certainly just an artifact of the way it's being measured. Unless your mouse is malfunctioning in a noticeable way, don't worry about it.
Offline itlnstln
[6gv2]
« Reply #14 on: Mon, 01 November 2010, 15:05:07 »
I can't tell the difference in just typing between PS/2 and USB. It would seem to me that if you could notice lag using a keyboard, you probably have other, worse problems.
Offline zhuak1
[6gv2]
« Reply #15 on: Mon, 01 November 2010, 15:07:29 »
just as..?
Offline Rajagra
[6gv2]
« Reply #16 on: Mon, 01 November 2010, 19:23:15 »
Let's take a step back. Did you first notice this lag when you changed the keyboard, or got the new motherboard? Are you using the same screen?
If you are sensitive to delays of a few ms, as some gamers say they are, it is entirely possible you are picking up on normal keyboard response time. We've measured internal key matrix scan times between 2.6ms and 10ms, but this may be added to by debouncing algorithms etc. This delay can't be overcome by any interface, though they may add an additional delay on top.
I can't help but feel this is rather academic for online gaming, where latency as low as 10ms is rare, and 50-100ms is pretty good.
Offline CodeChef
[6gv2]
« Reply #17 on: Mon, 01 November 2010, 20:27:22 »
Hey, what it seems to be is a phenomenon called rotational velocidensity. You see, newer hard drives have a lower rotational velocidensity, and it in fact affects every part of the computer. Even if your computer is only a year or two old, it can be affected by rotational velocidensity. The solution is to replace all the transistors on your motherboard with vacuum tubes. You see, tubes "fatten" up the signal. Because tubes are older than computers, they are not affected by velocidensity. Tubes were invented before computers were widely in use, and they also have no moving parts. The warm glow and fat tone of the tubes should alleviate any problems you might have. Be sure to order 12AX7 tubes for transistors located on the top of the motherboard (the side with the CPU, expansion slots, etc.) and 6V6 or 5881 tubes for the underside.
Hope this helps!
[sigpic][/sigpic]
Offline erricrice
[6gv2]
« Reply #18 on: Mon, 01 November 2010, 20:49:46 »
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Mañana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline zhuak1
[6gv2]
« Reply #19 on: Mon, 01 November 2010, 20:52:25 »
Thanks for your help. Im not a computer "genius",  but if that is true, this is happening long time ago before i switch computer. Since i bought this one i've switched like 50 times my mouses. So.. you mean that this is a common problem?
Offline CodeChef
[6gv2]
« Reply #20 on: Mon, 01 November 2010, 21:31:05 »
Dude, I was joking. There is no such thing as rotational velocidensity. Tubes would do nothing for your computer. I really have no idea what's wrong or how to help you. Consider yourself trolled :D
[sigpic][/sigpic]
Offline msiegel
[6gv2]
« Reply #21 on: Mon, 01 November 2010, 21:35:53 »
audiophile.
Offline muchadoaboutnothing
[6gv2]
« Reply #22 on: Mon, 01 November 2010, 22:13:26 »
Stealing jokes from reddit now, are we?
Offline zhuak1
[6gv2]
« Reply #23 on: Mon, 01 November 2010, 22:55:37 »
Im serious guys. ill give you an exact example.
I move the mouse from the beggining to the end of the pad
if i do it 1 time, 2 times, 3 times its normal and the 4th its like i have acceleration. ive tried mousefix the problem still in there. Maybe its that "1900hz" that sometimes shows me on mouse rate checker that does this?
Offline Fwiffo
[6gv2]
« Reply #24 on: Mon, 01 November 2010, 23:20:25 »
It's not likely to be anything to do with PS/2 vs. USB. I would start with your general computer diagnostics; start by checking for viruses, spyware, etc. that might be causing you performance problems. If you do suspect there is something wrong with the keyboard or mouse, try plugging them into a different computer and see if they perform the same way.
Offline AvengeR
[6gv2]
« Reply #25 on: Tue, 02 November 2010, 07:50:30 »
It could be a motherboard issue because of abusing usb ports.
I've encountered some issues with new motherboards (especially laptops) when using mouses at 500hz plus other things at the same time, for example wireless devices or "gaming products" that force 1000hz (can't be a good thing to use the power of 8 usb ports in only a keyboard or a mouse).
try ps/2 for your keyboard, and unplugging some other things as well.
Also your ime1.1 should get stable 500hz. I've not tried zowie products but it's the same sensor from wmo, regular ime1.1, ime3.0 and blue optical (1.1, from 2001 I think).
edit: the proper way to test it is to move your mouse fast and in circles in the mouse rate checker program. It's obvious but it's always worth mentioning.
« Last Edit: Tue, 02 November 2010, 07:54:04 by AvengeR »
Offline zefrer
[6gv2]
« Reply #26 on: Tue, 02 November 2010, 08:01:47 »
Quote from: zhuak1;241421
I actually understand what you mean (shock!). If it is what I think it is then it's not a hardware problem at all but something is running that causes your PC to 'stall' or lock-up for a few ms. Then it starts responding again. You see a higher Hz rating in the program because of the lock up causing mouse polls to be queued up and reported all at once when it starts responding again.
I would start with a new, clean OS install somewhere new (do not re-install over your old one..). Install graphics/input drivers and nothing else and test again.
Offline Rajagra
[6gv2]
« Reply #27 on: Tue, 02 November 2010, 08:08:26 »
I think USB's flakiness has been tamed over the years, but never quite gone away. I'm constantly grateful (and amazed) when it does work perfectly.
Offline zefrer
[6gv2]
« Reply #28 on: Tue, 02 November 2010, 08:18:47 »
Quote from: Rajagra;241369
I'll have to disagree with you there Raj. For online FPS a good ping is 20-30ms. However, playing with 50ms is a lot different than 30ms and most people wouldn't play seriously with anything over 70ms. It's not a linear '40ms is twice as bad as 20ms' kind of thing. The reasons for this are to do with the game itself rather than the ping and how each weapon works with the network code and with higher ping times.
And yes, a 2-5ms _input_ delay on top of a 30ms ping is instantly noticeable to anyone that spends a few hours a week playing FPS games.
Offline zhuak1
[6gv2]
« Reply #29 on: Tue, 02 November 2010, 08:47:22 »
I've installed OS like 100 times, nothing fixs. Used 2 pcs too. one asus p5p77 LX and now p5q pro turbo.
Ill switch boards, ill get and MSI sck 775. maybe its just asus fault. Its unplayable.
For you guys should i get an death adder? its the only mouse i havent tried already..
Offline zefrer
[6gv2]
« Reply #30 on: Tue, 02 November 2010, 08:50:33 »
Maybe you should find what the problem really is first before buying yet more hardware that probably won't do anything/isn't the problem.
If you have changed mouse/keyboard, pc, re-installed the OS, confirmed that no software is to blame and also that no hardware is to blame then what is left..? :)
Offline Fwiffo
[6gv2]
« Reply #31 on: Tue, 02 November 2010, 08:52:58 »
Quote from: zefrer;241525
I'm extremely skeptical that a delay that small is perceptible on top of other factors. There's a 17 ms delay between screen refreshes for goodness sake. Again, it would be a trivial thing to do a blind test to see if it's possible to tell the difference.
Offline zhuak1
[6gv2]
« Reply #32 on: Tue, 02 November 2010, 09:42:51 »
Guys, when i move too fast. the mouse just stop tracking. the sensivity has a delay.. thats my problem. it seems like i have LAG moving mouse to aim :\
Offline CodeChef
[6gv2]
« Reply #33 on: Tue, 02 November 2010, 09:52:40 »
Quote from: msiegel;241406
audiophile.
Guitar/bass player too!
[sigpic][/sigpic]
Offline zefrer
[6gv2]
« Reply #34 on: Tue, 02 November 2010, 10:02:41 »
Err what? 17ms delay between screen refreshes? Would _love_ to see references of where you got that from :D
And I was talking specifically about _input_ delay, not a 2ms increase in ping. Input delay is obvious, you would see it at the interface when selecting menu items for example or typing, before going into the game.
Offline Fwiffo
[6gv2]
« Reply #35 on: Tue, 02 November 2010, 10:19:02 »
LOL, I used *math*.
I'm assuming a refresh rate of 60Hz. So there is 1/60th of a second between updates of your screen. It isn't possible to update any given pixel on your screen faster than that at that refresh rate. 1/60th of a second is 0.016666... seconds or about 17ms.
After any input action, assuming your software, OS, input hardware, USB or PS/2 bus, etc. all collectively have ZERO lag, there's an average of 8ms before there can be any kind of feedback on the screen at all, hence my skepticism.
Offline zhuak1
[6gv2]
« Reply #36 on: Tue, 02 November 2010, 10:31:42 »
Guys, i saw some random guy saying that he was having unstabe hz too and the problem was the motherboard usb ports. maybe i have that problem too.
And nice, i've got a reason to RMA the keyboard. the SPACE key is making so ****ing noise it seems that its going to blow up. Maybe im going to buy EC1 & Tarantula. What do you think about this 2 gadgets?
and here's a print with my proof.
« Last Edit: Tue, 02 November 2010, 10:37:21 by zhuak1 »
Offline zefrer
[6gv2]
« Reply #37 on: Tue, 02 November 2010, 10:42:41 »
"Lol".. That would be the case if we were talking about CRTs with a 60hz refresh rate..
The 60hz on an LCD is a frame rate cap, what matters is the pixel response time which is some 2-5ms on most TN based LCDs.
« Last Edit: Tue, 02 November 2010, 10:45:25 by zefrer »
Offline zhuak1
[6gv2]
« Reply #38 on: Tue, 02 November 2010, 10:49:12 »
focus on my problem :((
Offline zefrer
[6gv2]
« Reply #39 on: Tue, 02 November 2010, 10:53:24 »
Sorry :)
As I said earlier the higher Hz can be a result of the PC locking up for a second or whatever which would also explain what you are describing. Since you say you have used another PC with the same problem what makes you think it's your motherboard's usb ports?
Offline zhuak1
[6gv2]
« Reply #40 on: Tue, 02 November 2010, 10:58:47 »
unstable mouse hz -» usb port? Since im only having this problem in Asus Boards... the mouse sensivity is really ****d up. i cant explain exactly but it seems that he gain acceleration and some times when you move fast or you do an 360/180 the mouse doesnt track.
Offline Fwiffo
[6gv2]
« Reply #41 on: Tue, 02 November 2010, 11:06:39 »
Can a mod split this thread?
@zhuak1: Have you tried hooking up with a PS/2 adapter just to see if there is a difference?
@zefrer: Your screen can still update, at most, 60 times per second. The pixel response time is the delay between when the display receives the signal and when the pixel's color has actually changed. If the DVI interface is operating at 60Hz, it's just not possible to get new information to the display more often than 60 times per second.
Offline zefrer
[6gv2]
« Reply #42 on: Tue, 02 November 2010, 11:10:50 »
Fwiffo that's not the case, LCDs do not work like that. Here.
Zhuak have you tried the same keyboard/mouse on another PC and had the same results or not? FYI Asus has some of the best and most stable motherboards on the market, I would expect you to _not_ have issues with it, not the other way around.
Offline zhuak1
[6gv2]
« Reply #43 on: Tue, 02 November 2010, 11:18:53 »
dont have this problems on lan, always stable.
[6gv2]
« Reply #44 on: Tue, 02 November 2010, 11:19:49 »
Quote from: zefrer;241618
Even so, Windows is going to allot an LCD 60 images a second. Via AVforums:
Quote from: AVSForum
Response Time
Strict Definition: The time required for a liquid crystal to change orientation.
Refresh Rate
Strict Definition: The time alloted for each frame of video to be displayed on the screen divided into one second. Active matrix displays like LCD use the entire alloted time to display a frame.
LCD blurring is a combination of long response-times and long hold-times. Reducing the response time with overdriving techniques does not help the hold-time. Reducing the hold time by increasing the refresh rate does not change the response time. You have to do both to really reduce blur.
And TweakGuides:
Quote from: TweakGuide
Ok, so if an LCD monitor doesn't refresh itself many times a second, why does an LCD monitor still require a particular refresh rate setting in Windows? We previously discussed the fact that refresh rates are something only a CRT monitor needs because of the way it physically operates. Well it appears that LCD monitors need to emulate a refresh rate in Windows primarily for compatibility purposes with games and hardware. Games, Windows and your graphics card are all still designed around composing individual frames in the frame buffer, and sending these whole frames to your monitor one by one, with the timing for buffer flipping typically based on Vertical Blank Intervals - all things which were originally required for CRT monitors. Therefore LCD panels have to try to operate on the same basis, despite the fact that they don't have the same physical limitations of a CRT.
Let's look at an LCD's theoretical refresh rate, based on its response time rating. Consider the example of an LCD monitor nominally rated at an 8ms response time. Given 8 milliseconds is 8/1000ths of a second, in one full second it can refresh all the pixels on the screen (if necessary) 1000/8 = 125 times, which makes it equivalent to a 125Hz refresh rate. Yet no 8ms LCD monitor allows you to set a refresh rate even remotely close to this in Windows.
Offline Fwiffo
[6gv2]
« Reply #45 on: Tue, 02 November 2010, 11:24:05 »
You're confused; if you read the article you would see:
Quote from: wikipedia
However, LCDs normally refresh at 60 fps and it is still possible to have screen tearing if graphics are updated too quickly.
No, LCDs don't have an electron gun that's scanning the screen, and I never said they did, but they still only update at 60Hz. It's not like the video card has random access to the pixels on the display, it sends an updated image at 60Hz. Read this article on the DVI interface if you're not convinced.
It's not a matter of being compatible with windows or anything, it's the way the interface between your video card and your display physically works.
Offline zefrer
[6gv2]
« Reply #46 on: Tue, 02 November 2010, 11:29:41 »
Yeah, I see it Fwiffo, I am confused indeed :) I'll read up more on it later
Offline Fwiffo
[6gv2]
« Reply #47 on: Tue, 02 November 2010, 11:33:08 »
OK, back on topic. :-)
Quote from: zhuak1;241621
Can you elaborate? Are you saying you only experience lag when playing over the Internet but everything is fine when you're playing over a LAN?
If so, then it's not the keyboard, mouse or USB bus that's at fault.
Offline zhuak1
[6gv2]
« Reply #48 on: Tue, 02 November 2010, 11:43:30 »
when i play at lan, the mouse sens seems to be ok. doesn't give me bad tracking or like "extra accel" and YES, i've tried ACCELFIX,CPL MOUSEFIX! :P
Its like a bug on my board, a bug on mouse hz, a bug on windows.. a bug in mouse. i dont know ill give an example
I move the mouse from here to here
X ------------------ X. Normal, with precision
then i move again
X ------------------ X. Normal..
Then i move again like the same as i was used to do and then..
X ----------------------------------------X like this. This really sucks when im playing..
Offline zefrer
[6gv2]
« Reply #49 on: Tue, 02 November 2010, 11:55:42 »
Again, have you tried this mouse/keyboard on another PC and had the same issue or not?
Do this. Disable your network connection and try your game again (not an online only game obviously). Do you have the same problem?
