Author Topic: Alps SKCM/SKCL plate specifications  (Read 15362 times)
Offline TomahawkLabs
« on: Wed, 19 February 2025, 11:01:51 »
Hello,
Does anyone have a document on the corner radius tolerance for Alps SKCM/SKCL plates? I know I found a document at one point, but neglected to save it anywhere safe. I can easily find the cutout specs, but they don't indicate the corner tolerance. I plan to make my own plates and am curious how tight of a corner I will need to mill them myself.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline jacobolus
Re: Alps SKCM/SKCL plate specifications
« Reply #1 on: Sat, 01 March 2025, 11:33:48 »
If you are cutting with a tool that has some wide kerf, you can also just extend your cut past the edge:
You probably aren't cutting through anything this solid, but for example:
Offline kajahtaa
« Reply #2 on: Sat, 01 March 2025, 13:04:05 »
btw - there are many good Alps plate files on Github for reference.
src: My Amano R2 with Pine Alps.
« Reply #3 on: Sat, 01 March 2025, 21:09:42 »
After digging around, the answer is dogboning the corners. Still working on the PCB, but it's the only logical answer for what I have access to.
SA: Camping
