Author Topic: Is there such a thing as textured stickers for key caps?  (Read 4958 times)
Offline Ki Bored
« on: Thu, 20 February 2025, 21:54:32 »
I have a Lenovo T16 laptop, and love every aspect of it except for the fact that I find the key caps too smooth and slippery when typing, and I end up making a lot of typing errors.
I was wondering if there's any way to add texture to the key caps on a laptop?  I thought one solution might be to apply small stickers with some texture on them to each key cap.  But not sure if there is such a thing.
Or if anyone has a different solution.
Thanks.
Offline TomahawkLabs
Re: Is there such a thing as textured stickers for key caps?
« Reply #1 on: Fri, 21 February 2025, 11:40:02 »
Unless you are using a macbook, I doubt there are any aftermarket to fit the unique layouts of laptops. You would likely be able to find success in finding a clear textured tape and cutting them to size.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline Ki Bored
« Reply #2 on: Fri, 21 February 2025, 17:11:01 »
Ah, right, thanks. Yeah, I wasn't looking to have the stickers fit or have qwerty letters on them, just something to stick on the caps to make them textured.
I will look around for some textured tape. Good idea.
Thanks again.
