Author Topic: Microsoft Trackball Explorer vs Kensington Expert vs Elecom HUGE.  (Read 71574 times)
Offline knightjp
When it comes to trackball usage, I've used the Logitech M570 and I still use one at work. I've used a Slimblade and it lasted for about 13 months before the main left click button stopped working. Currently using the Elecom HUGE and I like it. Its lasted the longest, however I feel that the top rubber part is now starting to wear away. I'm looking to changing it out, even though it still works really well. I've got a Logitech T-Cl13 on the way from ebay, but that is thumb trackball.
Looking for a finger operated trackball to replace the aging HUGE and I'm thinking of getting another one or the Kensington Expert or Microsoft Trackball Explorer.
The trackball explorer seems to be quite a popular choice even though its not being made anymore - much like the T-Cl13. Does it really better than the Expert or HUGE?
Offline YALE70
    • Hackjob
Re: Microsoft Trackball Explorer vs Kensington Expert vs Elecom HUGE.
« Reply #1 on: Sat, 08 March 2025, 16:25:15 »
Never tried the Kensington Expert, but I have both the Huge and the Microsoft Trackball Explorer (MTE).
I much prefer the MTE. I find that the Huge splays my hand out too flat while the MTE leaves my hand in more of a natural resting position. The 46mm ball strikes a good balance between speed and precision in my opinion, and the fact that it sits a little higher than the ball on the Huge makes it less prone to accidental button hits when swiping. Plus the chrome steel bearings will probably feel smoother than the infamously rough stock ruby bearings of the Huge. I even swapped the bearings in my Huge for G5 precision chrome steel bearings and I still think my MTE on stock, good conditioned bearings feels just a little smoother.
You will lose some buttons though. The MTE also doesn't have the forward and back thumb buttons, the tilting scroll wheel, or the two index finger buttons that the Huge does. Software experience is about equal between the two - program specific profiles, remapping, and whatnot. You will need to find the old Intellipoint drivers on the web. I find I have to clean the junk off the bearings at least once a session.
Some other tips:
  • Try and get an X08 model MTE instead of an X05 model. Supposedly X08s were made with better plastic and they don't get brittle like X05s commonly seem to - though it could just be that X08s are generally newer.
  • The paint and textured surfaces on the MTE will wear with time (if they haven't already).
  • The default right click for the MTE is set above the scroll wheel so you might want to remap it the ring finger (like it is on the Huge) using the Intellipoint software.
  • It has an old sensor. Be prepared to adjust the pointer speed/use mouse acceleration if you have a particularly high resolution display. To me it feels fine on Windows defaults with my 3440x1440 ultrawide, but anything higher than that, you might want something capable of higher DPI.
  • The bearings might be worn - these are roughly two-decade old devices after all. Replacements I believe are 2mm, or you can actually just flip the old ones around to an unworn side. You will need to use a small drill bit to bore a hole behind them so you can push them out, but otherwise swapping them isn't too difficult.
Alternatively, look into the Ploopy Classic or the Sanwa Gravi. The Ploopy is basically a near-exact 3D printed clone of the MTE albeit with modern hardware and roller bearings. It is quite expensive though. The Gravi is much cheaper and extremely similar to the MTE, but wireless and a better sensor. Not sure on the build quality though.
Offline knightjp
« Reply #2 on: Sun, 09 March 2025, 16:33:07 »
Thanks @YALE70 for the reply.
MTE does sound good and I think I might get one; even if it won't be my daily driver. I guess if someone is actually copying and making a direct replica of it (Ploopy), that's a testament to how good and popular it is and certainly earn it a place in anyone's collection.
Offline YALE70
    • Hackjob
« Reply #3 on: Sun, 09 March 2025, 20:25:36 »
Awesome, I think you're really gonna like it. It's one of the few vintage trackballs that's actually still quite viable in this day and age.  ;D
Offline knightjp
« Reply #4 on: Mon, 10 March 2025, 01:25:30 »
Thanks. I got one off ebay for a good price I guess. It's on the way.
Offline YALE70
    • Hackjob
« Reply #5 on: Wed, 12 March 2025, 00:53:26 »
I started trying to use the Huge again. Moving states, so a wireless trackball seems like a good idea for the interim without all my stuff.
God, I forgot just how much I hate the shape of this thing, and it feels scratchier and "muddier" than I remember - even with the bearing swap. Doesn't glide very well but the stiction is still low, which is good at least. I think the ball has got some blemishes on it.
Placed an order for a wireless Gravi and I'll report back if it's any good. Maybe even write a review about it here.
Offline knightjp
« Reply #6 on: Thu, 13 March 2025, 03:18:59 »
I have heard a number of people talk about how scratchy, etc., the HUGE is and that the bearings absolutely need to be changed. I've not faced any of those issues. It did feel a bit scratchy at the beginning, especially in the scroll wheel and myself coming off a Kensington Slimblade. However, soon it became more and more smooth. I've noticed that most of the reviews are for the wireless one. Mine is an older wired model. Maybe there is a difference the bearings that were used.
All in all, I do like the HUGE, but I would like to move on and experience other trackballs as well.
Offline YALE70
    • Hackjob
« Reply #7 on: Thu, 13 March 2025, 18:00:09 »
Interesting. I think the quality of (double entendres incoming) balls from Elecom might have something to do with the issues as well. IIRC, I tried cramming the ball from a Logitech Marble FX into the Huge and it felt smoother than the stock ball. Maybe a difference in surface finishing? Though it could just be my FX ball is in generally better condition than the ball out of my Huge. Either way, judging by the number of complaints I've seen about stiction with Elecom trackballs in general, they certainly have a consistency problem somewhere.
Also, the Gravi just showed up today. I can't test or compare it with my MTE since all my stuff just got boxed up by the movers but, oh man - it immediately fits so right in the hand. The shape is like ninety percent identical feeling to the MTE and the ball is just as smooth, if not smoother feeling. It's about the same size and rides on ceramic bearings from the looks of it. Scroll wheel feels about the same. Biggest difference is the buttons; they feel less spongey and easier to press than on the MTE. We'll see how it holds up long term in actual use but just off first impressions, this feels like it could be the perfect MTE substitute.
Offline YALE70
    • Hackjob
« Reply #9 on: Sun, 16 March 2025, 20:52:47 »
Now that I've started using the Sanwa, I do actually have a few gripes about it now. Firstly, Sanwa decided to keep the same default layout as the MTE, so right click is on the thumb cluster instead of your ring finger. That's like... the one thing they absolutely didn't need to mimic from the MTE. Second, the default sensitivity levels seem way too high (1000, 1600, and 2400). I prefer something in the range of 600-800. Of course, none of those issues are likely permanent as you can just reconfigure the trackball with the customization software - as long as you're on Windows.
Sanwa didn't even bother making Mac or Linux versions of the customization software, and that's just a huge ball buster because it means those users are stuck with the insipid default layout and sensitivity. I brought my Mac Pro with me to the hotel I'm staying at and I spent the better part of the evening looking for remapping software that would work with this thing (so far, LinearMouse has been the best, and it's free). Still, it feels great, but I'll probably like using it more on my Windows machine.
There is a similar MTE clone called Nulea. https://www.amazon.ae/Nulea-Rechargeable-Rollerball-Adjustable-Compatible/dp/B0CF4KF8RN/ref=sr_1_51?crid=NHFJ7XWJTRWA&dib=eyJ2IjoiMSJ9.GsGby8P2Go99Lj2Uq8fbWAr0Jz5-RhN4AGpD7KFshXU2MEIDX2pz-zoJeoyC5fvCyh1lqr2Z6GfGNVDgwHnLYBMOUJdZ1PlUMsCbc_Y2ipAwbJGZ95QJVMxLwdolfbdgHr_HKZFo140BYe2-laVwh2JemZAT_mIq5eMdU-o7uVUnvWptPfbD53MB5kgnW9jjDopltmxLFw1W9K1LdRkkVAc5Ir52X5Lrjw0Atm3cocijR5m3og-go4HjWelE43KstxG4dtPYeyKFIGZ0SfLy5aPzdX8MiZexZBtUFdbUuuttnJRZRuVE_s-Fk9vKIcwi2v2IyrdjuI3BPQSdBWR2qwPHIFZCW3Mld99ELgYySLFwm-GtZEtiwo9AEwnVtOvmRSs4Dkmlc56kP9TPSWJoePu_RfIUAZ40uezu6InwiS1V1-jG8_iyu-hD4FlHRS2Y.xTWDeBGbqIwa4M8ERTLZRXgj_dRRHFQLU8LqG6M_ivI&dib_tag=se&keywords=trackball%2Bsanwa&qid=1742104782&sprefix=trackball%2Bsanwa%2Caps%2C284&sr=8-51&ufe=app_do%3Aamzn1.fos.b4f74a7b-9d54-420b-9003-7e54957e6f89&th=1
I've seen those. Shape looks almost identical - like they could almost be from the same underlying manufacturer. The Nulea trackballs seem like they have a few features the Sanwa doesn't like USB-C , rechargeable battery, and RGB on some models. No customization software for any OS from the looks of it either, so that's probably the main tradeoff. Only other reason I wasn't driven to pick one of those up was the lack of a pinkie button like the MTE, but I guess that probably isn't a huge deal breaker for most.
Actually, I think they might work better than the Sanwa for Mac and Linux users since they have the "correct" default layout and a greater range of DPI settings. I'd hope the physical quality and feel is at least on par though.
Offline knightjp
« Reply #10 on: Mon, 17 March 2025, 04:12:54 »
I didn't know that was the standard layout for the MTE. Makes me wonder why do users hold it in such high regard then?
Being in Dubai, trackballs are not common, unlike gaming mice. So most people over here don't even have a clue. The only trackballs I've seen in tech shops are Logitech M570 and Trackman marble FX. My knowledge only comes from watching reviews on Youtube and posts on here.
Offline YALE70
    • Hackjob
« Reply #11 on: Mon, 17 March 2025, 12:27:00 »
It's the shape and lasting compatibility with modern systems. The layout is easily reconfigurable with the software otherwise.
I still don't get why Microsoft went with that mapping. AFAIK Logitech had been using the right click on ring finger on their fingertip trackballs long before the MTE. In my opinion that feels way more natural - closer to a traditional mouse with right click under the middle finger.
Offline Stupidface
  • Lifelong edge use case
« Reply #12 on: Fri, 14 November 2025, 05:33:50 »
I wanted to check: d'you mean to say they are still offering these:
315354-0
...in Dubai?
I have something of an interest in Logitech products from that era*, so I hope you won't blame a chap for enquiring about further particulars.
*"That era" being an ellipsis of "back when peripheral manufacturers actually gave a monkey's about build quality."
Offline knightjp
« Reply #13 on: Wed, 19 November 2025, 02:07:27 »
I hear you about the quality.
The trackman Marble FX I'm referring to is this one.
315400-0
After seeing the video of Eric S Raymond on the Tech Syndicate youtube channel, and his logitech thumball, I decided to get one of them for myself. Obviously it had to be an ebay item shipped from the US.
Offline avareed
  • Location: 27 Strickland Street, Denmark WA 6333, Australia
  • Stay curious, keep building,
« Reply #14 on: Thu, 20 November 2025, 01:38:44 »
I’ve tried all three at different times, and each one shines in a slightly different way. The Microsoft Trackball Explorer still feels amazing for a thumb trackball, very natural grip and easy flicks, but it’s harder to find now and of course it’s an older wired device. The Kensington Expert is great if you like using your fingers on a big ball, and the scroll ring is a huge plus for long documents or browsing. The Elecom HUGE sits somewhere in between for me: more buttons and features than the Explorer, more “gamer / power user” style than the Kensington, but it takes a bit of time to get used to its size.
If I had to sum it up:
Comfort / nostalgia: Trackball Explorer
Productivity and scrolling: Kensington Expert
Customization and buttons: Elecom HUGE
In the end, hand size and whether you prefer thumb or finger operation matter more than specs on paper. If possible, try the shape first, because that decides everything.
Stay curious, keep building, and share what you learn.
Offline Stupidface
« Reply #15 on: Tue, 25 November 2025, 00:48:02 »
Thank you for the clarification. [tips hat]
I think I found the video here:
Great stuff.  There are some nice lingering shots of a grey-corded, PS/2, T-CL13/Logitech TrackMan Marble+ (the "+" indicates the addition of a scroll wheel) at the 7:38-7:45 mark.  I recognised it because I used its white-corded, USB connector successor (the T-BB13) for many years.  There were times when I wanted to have a comparatively inexpensive spare on hand for travel and connecting an active PS/2-USB adapter to a T-CL13 effectively gets you a T-BB13, but for less money.
Any road, I am grateful to you for mentioning the video because…well, I’ll see if I can explain.
Yonks ago, Eric S. Raymond wrote this webpage:
http://www.catb.org/esr/trackman-conversion/
On it, he talks about how the three-button Trackman T-CL11 is a near-perfect pointing device whose ergonomics are unmatched, then goes on to moan about Logitech adding a scroll wheel, putting a switch in it, and having it serve as a middle button on subsequent Trackman models.
The problem (according to him, at least) is that this change makes possible to accidentally scroll-click when you mean to click.  So two button + clickable scroll wheel models are a “deal-killer” (again, according to him).  As the page shows, he put a lot of work into attempting to update his three-button, PS/2 trackball to a USB device.
And now, ages later, I see a video that shows him using… a T-CL13 Trackman with scrollwheel.  Interesting - I wonder what prompted him to change his view?
I'm afraid I overlooked it before, but I believe this is a reference to the T-CL13 you mentioned in your initial post.  Can you please tell us about your experience with this device and why it (presumably) did not work out?
(Specifically, can you tell us whether the 300 dpi resolution proved to be a stumbling block?)
« Last Edit: Wed, 26 November 2025, 00:51:52 by Stupidface »
Offline YALE70
    • Hackjob
« Reply #16 on: Wed, 26 November 2025, 11:31:30 »
I have two older Logitech trackballs with the old 300 DPI sensor (Marble FX and LCOT).
Those sensors are pretty horrendous with modern systems, IMO. You're basically forced to crank the pointer speed in order to get some semblance of responsiveness on a modern display and even then, the sensor is so slow that your cursor will stall if you swipe the ball too quickly.
It's even worse on the LCOT because the polling rate over the old 27 MHz RF wireless is less than 60 Hz, so the jitter is just absolutely terrible. I can't believe Logitech sold that thing well into the 2010s without a single hardware update.
Sucks because the shape of those trackballs are absolutely brilliant. I'd shell out for one if Logitech ever decided to update them.
« Reply #17 on: Thu, 04 December 2025, 00:25:28 »
It's super cheap, and honestly not bad functionally.
I've had one for almost 6 years, and it still works perfectly.
I was gonna upgrade when it broke, but it still hasn't!
I'd vote the Logitech Trackman as a super cheap/emergency option
