Author Topic: Gifted a vintage keyboard  (Read 5991 times)
Offline jcoffin1981
« on: Sat, 08 March 2025, 21:28:50 »
I was gifted a Dell AT101W keyboard with ALPS black lightly tactile switches by a doctor friend who knew I was an enthusiast.  I am having quite a bit of trouble to get this working.  The connection is PS/2, but that in itself should not be much of an issue.  I am using a PS/2 to USB-A adapter.  When plugged in the device manager states that there is an uknown USB device and that "(port reset failed) I have tried multiple USB ports and have unsuccessfully searched for drivers.  If I allow Win 10 to search for drivers it says tat the best driver is already installed.
I have gone to the Dell Website and it does not know my device not have compatible drivers available.   I'm not sure what to do.  I would have liked to tear it down and restore it, but at this time I may just sell it for parts.  Any advice would be appreciated.  Thanks a bunch!!
Re: Gifted a vintage keyboard
« Reply #1 on: Sun, 09 March 2025, 04:08:30 »
Sounds like the problem is the adaptor. Have you tried another adaptor?
<turning on the info-tap>
There are two types of PS/2 to USB adaptors. Passive and active.
The passive ones are for keyboards that talk both PS/2 and USB ("combo") and is able to auto-detect which it is connected to. Those are typically quite small, and in green (for mouse) or purple plastic (for keyboard) and contain only wiring inside but no actual electronics.
If you are trying to use one of those, it won't work with the Dell AT101W. You'd need an active adaptor. Those are also known as "protocol converters".
The active ones often have a cable, with a little box, and two PS/2 ports: one for mouse and one for keyboard. Beware of dubious sellers on eBay though, trying to sell passive adaptors as "converters".
There have also been some active adaptors that have not worked with keyboards with larger power draw, such as older Model M. But the Dell AT101W is fairly common and I've not heard that there would be such problems with it.
People have built their own converters with a Pro Micro,  TMK firmware and sometimes placed them inside their keyboards.
« Last Edit: Sun, 09 March 2025, 04:58:45 by Findecanor »
