Author Topic: HHKB PRO2 vs HHKB PRO  (Read 2892 times)
Offline codek
« on: Mon, 01 November 2010, 04:05:22 »
Is there any difference?
Offline Rajagra
« Reply #1 on: Mon, 01 November 2010, 04:24:35 »
Just the USB hub, I believe.
Offline Moogle Stiltzkin
« Reply #2 on: Mon, 01 November 2010, 04:26:18 »
Do they both support NKRO ?
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline Rajagra
« Reply #3 on: Mon, 01 November 2010, 04:28:26 »
Yes, within the USB limits.
Offline itlnstln
« Reply #4 on: Mon, 01 November 2010, 07:47:28 »
The Pro2 also added Mac support, IIRC.
Offline Rajagra
« Reply #5 on: Mon, 01 November 2010, 20:25:01 »
The original Pro had Mac support (legends and DIP settings.)
Offline iMav
  • geekhack creator/founder
« Reply #6 on: Tue, 02 November 2010, 02:32:41 »
Quote from: codek;241003
They are close enough to do this.  ;)
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #7 on: Tue, 02 November 2010, 02:45:07 »
They are pretty similar as everyone here has already noted. The only other differences I can immediately tell is that the pcb and controler are slightly different and moved around a bit. Some of this has to do with the Dual USB and some probably has to do with maybe better/smaller tech.
Ooops! I almost forgot, the older HHKB Pro 1 has slightly thicker and heavier keycaps compared to the HHKB Pro2. I think it was only like 2 tenths of a gram more though. I don't know if that was a long lasting or consistent trend though. And it certainly does not make a noticable difference.
I dig imav's 50/50 cookie board too =)
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
