Author Topic: Kensington Turbo Mouse with Slimblade Internals  (Read 24036 times)
Offline knightjp
« on: Mon, 10 March 2025, 01:23:50 »
Just a thought.. I like the look of the Kensington Turbo, especially for a retro style system project I'm in the middle of. However the lack of scroll wheel is an issue for me. I've used the Slimblade before and love the scroll function in it. Wondered if it was possible to retrofit the internals of the Slimblade into the Turbo housing.
Offline kurplop
  • THE HERO WE DON'T DESERVE
Re: Kensington Turbo Mouse with Slimblade Internals
« Reply #1 on: Tue, 11 March 2025, 07:55:01 »
I've fitted a few Slimblades into other housings and found they were pretty versatile because the flexibility of the PCB's. There are two that tightly hug the ball socket and the third is attached with wiring cables that allows a little relocating to fit. It will still require some moderately skilled techniques but it will likely fit.
Offline YALE70
    • Hackjob
« Reply #2 on: Tue, 11 March 2025, 11:57:27 »
I found this GitHub project for a 3D printed Marble FX-like mouse that uses the SlimBlade's style of ball twist scrolling. You apparently need two sensors to make it work, so it could get kind of expensive if an open source solution is more your cup of tea.
https://github.com/monroewilliams/trackball
