Author Topic: [IC] Hydro 8x - Hydroxyl Lab  (Read 8419 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Mon, 10 March 2025, 09:15:08 »
IC FORM
Hydro 8x
by Hydroxyl Lab
Post edited by Click Clack
Hello everyone, this is a new project brought to you by Hydroxyl Lab. Es, the founder, in collaboration with Click Clack wanted to share this beautiful keyboard with the community!
Hydroxyl Lab is excited to present its first product since the studio’s independence: Hydro 8X, part of the Project: Alteration series.
Index
- Design
- Structure and Internals
- Specifications and Layout
- Product Showcase
- Pricing and Vendors
- Follow the development
Design
Front View
As the primary visual component of the keyboard, we avoided overly complex designs. The addition of the F13 key ensures harmony and symmetry in the 7u layout, while also providing extra key functionality in the 6.25u layout. The keyboard follows the "Dot & Line" design philosophy, featuring rounded dots and curves for a cohesive, soft aesthetic.
The visual focal point on the front is the light strip above the arrow keys, continuing the "Dot & Line" theme. The strip is divided into two parts:
•   Dot: A tactile button for adjusting RGB lighting.
•   Line: An elongated ambient light strip.
The metal trim of the light strip extends to the middle frame, enhancing design cohesion.
As the debut product of the Project: Alteration series, Hydro 8X embodies modularity through its interchangeable blockers. The name "8X" originates from this feature: two WKL-style blockers and two HHKB-style blockers are included, allowing users to experience three layouts with a single keyboard (Note: WKL and HHKB layouts require a 7u spacebar).
Side View
The side design adopts a layered construction, combining the top case, bottom case, and decorative weight in a golden ratio (0.618) for visual harmony. The metal trim extends seamlessly to the middle frame, highlighting your unique configuration. Rounded edges on the top case, rear opening, and bottom case ensure a refined, ergonomic profile.
The USB-C port features a "sandwich" design, where the curved bottom case (crafted from varied materials and finishes) is nestled between the top case and decorative weight. This creates striking visual layers, with matching curvatures for aesthetic unity. The keyboard’s name is subtly engraved on the right side.
To showcase personalized configurations, the front-side panel also employs a layered design, adding visual intrigue and allowing users to admire their setup.
Back View
The back design emphasizes versatility through three elements:
1.   Upper Decorative Weight: Features minimalist "Dot to Line" engraved patterns for understated elegance.
2.   Central Recessed Strip: Displays the studio’s name, complemented by dual raised strips that contrast with the engraved grooves for depth.
3.   Lower Extended Base: Completes the layered aesthetic while balancing proportions.
For enthusiasts seeking premium weight options, we offer full copper variants:
•   1.1kg Copper Weight (red brass + yellow brass)
•   2.95kg Full Copper Base (red brass + yellow brass)
All copper components are treated with transparent nano-coating to prevent oxidation.
As a daily-use 80% layout keyboard, internal durability is paramount. Users can choose from three structures:
•   Top-mounted plate
•   PCB gasket
•   Beryllium copper structure
Magnetic contact pins replace traditional cables for easier assembly. Hydro 8X omits quick-release mechanisms due to safety concerns with heavier copper builds, opting instead for internal screw locks.
PCB Options:
•   1.2mm flex-cut black core PCB
•   1.6mm non-flex yellow core PCB
•   Typing angle: 7°
•   Pre-assembly weight: ~4.6kg
•   Post-assembly weight: ~5.1kg
Key Features:
•   Supports soldering, 7-pin hot-swap, stepped Caps Lock, split right Shift.
•   7u spacebar enables WK, WKL, and HHKB layouts via interchangeable blockers.
•   Single-mode (wired) only.
Product Showcase
Color Options & PVD Finishes
More Photos:
Pricing and Vendors
Pricing:
To be determined.
Vendors:
NA: ClickClack
SG: KTechs
AUS: TORO
More will be updated.
Join ClickClack’s Discord for the latest updates, discussions, and questions:
Fill in Interest Check Form:
Follow ClickClack's IG for other new projects:
« Last Edit: Thu, 13 March 2025, 06:17:43 by ClickClack.io »
Offline hwalker84
Re: [IC] Hydro 8x - Hydroxyl Lab
« Reply #1 on: Mon, 10 March 2025, 10:22:01 »
Yeah this is hitting everything I love. Side profile is going hard. I’m in.
    • clickclack.io
« Reply #2 on: Tue, 11 March 2025, 05:36:20 »
KTechs added as regional vendor for Singapore!
    • clickclack.io
« Reply #3 on: Thu, 13 March 2025, 06:18:07 »
TORO Studio added as AUS Vendor!
