Author Topic: Desoldering cherry switches video  (Read 2618 times)
Offline SirClickAlot
    • http://www.mrinterface.com
« on: Mon, 01 November 2010, 08:26:37 »
For those interested :
Me de-soldering cherry switches :
[Succes is when you get what you want
Happiness is when you want what you get]
Optimize your interfaces : http://www.mrinterface.com
Currently using( not necessarily my favorite : I iterate over my collection many times ):
Filco White Majestouch Mx Brown DS White on Black.
Looking for : New and interesting interfaces. Working on :www.deskthority.net
Offline Brian8bit
« Reply #1 on: Mon, 01 November 2010, 08:34:59 »
The English name for it is the sucker-upper-device.
« Reply #2 on: Mon, 01 November 2010, 09:19:34 »
Quote from: brian8bit;241068
Whahahahahahahahaa.....
Offline Parak
« Reply #3 on: Mon, 01 November 2010, 13:10:59 »
I wonder if it's possible to heat up all 4 solder points of the switch and then pull it out - like with a heat gun or similar..
Offline Zen
« Reply #4 on: Mon, 01 November 2010, 14:31:01 »
http://en.wikibooks.org/wiki/Practical_Electronics/Desoldering#Hot_Plate
Works fine with regular electronic components but I haven't tried with Cherry-switches,
maybe the plastic doesn't like the heat ?
Offline Zen
« Reply #5 on: Mon, 01 November 2010, 14:42:45 »
Offline Parak
« Reply #6 on: Mon, 01 November 2010, 15:15:11 »
On the other hand, it might melt the stabilizing pins first, especially on the rohs boards. Anyone want to try this first? :D
