Author Topic: Realforce 103UB Keycaps?  (Read 2568 times)
Offline imagine7xy
« on: Mon, 01 November 2010, 11:28:32 »
Hello, I type in both QWERTY/DVORAK so I was hoping there would be a way to get a set of blank keycaps for the board - perhaps not the entire board but just where the two overlap. Does anyone know if there is such a thing, or if the Blank keycaps that elitekeyboards.com sells for the HHKBP2 would work on other Topre boards the same?
Offline imagine7xy
« Reply #1 on: Mon, 01 November 2010, 11:49:44 »
Quote from: ripster;241113
The HHKB blanks would fit.  I bought a spare set for my RealForce 87U.
Great, do they match the color of the Realforce (UB models) as well? I am going to buy some then.
Offline itlnstln
« Reply #2 on: Mon, 01 November 2010, 11:52:13 »
Quote from: imagine7xy;241124
Yes. Since you're buying blanks, it won't matter much, but the HHKB has a slightly different font than the RF line.
Offline keyboardlover
« Reply #3 on: Mon, 01 November 2010, 13:05:23 »
Quote from: itlnstln
Well, buying blanks is always better than shooting blanks...
...I always say...
Offline magictoaster
« Reply #4 on: Mon, 01 November 2010, 14:45:35 »
Quote from: ripster;241166
The font is different?
Looks similar, but larger.
Offline itlnstln
« Reply #5 on: Mon, 01 November 2010, 14:58:56 »
Larger on the HHKB, that is.  The modifier keys are the same, though.
