Author Topic: Topre Realforce 86u/87u key remap problems on Mac?  (Read 5327 times)
Offline kbrint
« on: Mon, 01 November 2010, 13:08:09 »
Comrades,
I am considering a Topre Realforce keyboard.  I remember reading about someone having problems remapping the Alt and Windows keys on MacOS.  I need the bottom row to be Caps, Alt, Cmd, Space (left to right)...
I know the Caps is not a problem due to the hardware switch.  But, I can't seem to find the article that I saw before, despite considerable googling.
Are there any Topre Mac users that can confirm it's possible?
-kb
woody
  •  Guest
« Reply #1 on: Mon, 01 November 2010, 14:37:34 »
Quote from: ripster;241170
Dos vedanya.
?? ???????? (do svid?nija).
You need to practice more.
________
Ferrari F1/86 specifications
« Last Edit: Sat, 05 February 2011, 14:12:05 by woody »
woody
  •  Guest
« Reply #2 on: Mon, 01 November 2010, 14:43:18 »
So, which online shop sells 86u?
________
buy vaporizers
« Last Edit: Sat, 05 February 2011, 14:12:33 by woody »
woody
  •  Guest
« Reply #3 on: Mon, 01 November 2010, 14:47:08 »
For a good time, don't watch this:
http://www.imdb.com/title/tt0944835/
________
Rolls-Royce Twenty
« Last Edit: Sat, 05 February 2011, 14:13:11 by woody »
Offline dangerous
« Reply #4 on: Fri, 21 January 2011, 06:35:37 »
I'm looking at the 103U, which i think is similar to the 86U ... on the right hand side it has a "menu" key instead of a windows key.  Is this also easily mapped to option?  Is there anywhere I can get replacement keycaps to make it more maclike?  (Also, the 103UW from elitekeyboards.com seems to come with a keypuller but doesn't mention swappable control and caps lock keys.  Does anyone know if they are included, or where one can purchase them?)
Offline acolomba
« Reply #5 on: Fri, 21 January 2011, 07:04:32 »
For the right "menu" key, I'd recommend KeyRemap4MacBook. It will happily remap that key to any function key you want, along with a boatload of other options.
