Author Topic: 【IC】Alpha75: Open-Framework Modular Mech Keyboard Next-Gen Structure  (Read 5676 times)
Offline kKeyPower
‌Introduction‌
Hi everyone! Let m[/glow]e introduce the ‌Alpha75‌ – a groundbreaking modular mechanical keyboard built around industrial-grade aluminum framing and standardized components.
‌Modular Design‌
Unlike any keyboard before it, the Alpha75 uses ‌interconnected aluminum extrusion beams‌ as its core structure. All other parts are secured to the frame via ‌dovetail groove slider nuts‌ and matching screws. This means you can freely swap modules whenever you want to change functionality or aesthetics – ‌no permanent modifications required‌.
‌DIY Simplicity‌
The Alpha75 is designed to make DIY accessible. All six faces of its core frame (top cover, baseplate, side feet, USB-C panel, and inner panels) use ‌flat sheet materials‌. Just provide a design file or layout, and you can ‌create your own customized version‌ with basic tools.
‌Expansion Capability‌
Each ‌EU-standard 1515 aluminum profile‌ on the Alpha75 features ‌4 T-slots‌, giving the entire framework ‌16 expansion channels‌. Attach any module using dovetail nuts/screws, and remove them later ‌without damaging the frame‌.
‌Innovative Structure‌
The Alpha75 introduces our patented ‌CENTER mounting system‌:
‌Rigid Mode‌: Fixes the internal assembly firmly to the frame, delivering crisp acoustics and keystroke consistency that outperforms traditional TOP mounts.
‌Flex Mode‌: Provides centralized softness (20% more flex than conventional gasket designs) while maintaining even keypress response across the board.
Swap ‌internal suspension brackets‌ to mix-and-match structures, plates, and switches for distinct typing experiences. Check the sound tests below with different configurations:
‌Join the Conversation‌
We’d love to hear your thoughts! Leave comments below or dive deeper into discussions on our ‌Discord server‌: [https://discord.gg/hvpQvMbz]
‌Key Technical Notes‌
Frame: European standard 1515 aluminum profiles (4 slots/beam)
Compatibility: MX-style switches, QMK/VIA firmware ready
Modular Interface: M3/M5 dovetail slider nut system
This translation maintains:
‌ALPHA 75 Specifications‌
‌PCB‌:
‌Tri-mode connectivity‌: 2.4GHz wireless + Bluetooth 5.3 + USB Type-C wired.
‌Multi-device support‌: Simultaneous connection to ‌5 devices‌.
‌Thickness‌:
‌Non-RGB PCB‌: 1.6mm.
‌RGB PCB‌: 1.2mm (black-core, slot-cut design).
‌Case‌:
‌Material‌: European standard 1515 aluminum profile.
‌Colors‌: Black (anodized) / Silver (natural aluminum finish).
‌Structure‌:
‌Mounting type‌: Center-mounted (similar to top-mounted feel and acoustics).
‌Modular design‌: Supports multiple internal configurations via swappable ‌internal modules‌.
‌Key Features‌:
‌Customizable components‌:
Left/right ‌footbars‌ (adjustable tilt).
Top/bottom ‌plates‌ and front/rear ‌bezels‌.
All six exterior panels can be replaced ‌without tools‌ (tool-free design).
‌Customization options‌:
Colors, materials, patterns, and ‌cutout designs‌
Need adjustments to emphasize specific features? Let me know!
Offline zegonix
there is an extra thread for interest checks.
Offline KimJongUwU
This looks absolutely wild, can't wait to hop on the IC when its posted in the proper thread.
Offline kKeyPower
thiank you
Offline KimJongUwU
When are the IC forms going to be available?
Offline KimJongUwU
That takes you to the main post with the Discord, but not the IC form
