Author Topic: Typing with shoulders relaxed  (Read 3691 times)
Offline jeyoung
« on: Tue, 02 November 2010, 15:48:27 »
Every single ergonomics guide recommends typing with the shoulders relaxed. Is that even possible!?
Offline Daniel Beaver
« Reply #1 on: Tue, 02 November 2010, 16:39:42 »
Sure, that's how I do it. Why is it problematic for you?
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline jeyoung
« Reply #2 on: Tue, 02 November 2010, 17:07:08 »
Quote from: Daniel Beaver;241767
Well, although I consciously start out with my shoulders relaxed, after five minutes I find that they are tense and hunched. Besides don't movements of the forearms and fingers systematically tense the shoulders?
Offline Lanx
« Reply #3 on: Wed, 03 November 2010, 01:27:11 »
sounds to me that your source material is tensing you up, like your typing with rage type of deal.
I'm not saying your nerd raging when your typing but you should just try to examine what is happening when you are typing i guess. at least from my point of view i only get tense when i get client emails and usually those emails are the enfuriating kind.
Offline Half-Saint
« Reply #4 on: Wed, 03 November 2010, 01:57:52 »
How high is your chair compared to the table?
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline Rajagra
« Reply #5 on: Wed, 03 November 2010, 03:59:31 »
I think your chair back needs to be wide enough to stop your elbows from being pushed backwards by the turning moment of force from the weight of your forearms.
(I must learn how to shorten my sentences.)
Offline jeyoung
« Reply #6 on: Wed, 03 November 2010, 04:12:38 »
The height of my chair is OK, I guess, as my forearms are level with my wrists when my shoulders are relaxed. The difficult part is keeping them this way after I have started typing.
I think Lanx makes a good point. Most of what I type is code, and when I'm concentrating on the problem at hand, it's easy to forget about good posture.
Offline alec
« Reply #7 on: Wed, 03 November 2010, 06:16:48 »
adjustable elbowrests should eliminate this problem
Noppoo Choc Mini
