Author Topic: [In Stock] Stars 21 20% Programmable Aluminum Mechanical Keyboard  (Read 13523 times)
Offline john08099
  • Velocifire MK
  • * Moderator
    • Mechanical keyboards for typers
Stars 21
Designed by Weikav Studio
Color Options
Features
1. Diamond-cut craftsmanship with PC material "Breaking out of the cocoon" design: The product uses high-end diamond-cut processing techniques and a PC material "Breaking out of the cocoon" design, adding a unique metamorphosis aesthetic to the product.
2. Anodizing/Electrophoresis process, 180-mesh sandblasting treatment: The product uses anodizing/electrophoresis surface treatment and 180-mesh sandblasting, resulting in an exquisitely smooth and silky touch.
3. Triple-mode connection: The product supports wired, 2.4GHz wireless, and Bluetooth connection modes, meeting the needs of different usage scenarios
4. Supports QMK and VIA: The product supports QMK and VIA custom firmware, allowing users to personalize the settings according to their preferences.
Specification
Mount: PCB Gasket
PCB: Hot-swappable
Weight feature: Anodized gold weight
Process: Electrophoresis(Milky white), Anodized (other color)
Case Material: CNC Aluminum
Battery: 800mAh
Connectivity: Wired, 2.4GHz Wireless, Bluetooth
Polling rate: 1000Hz (Wired/2.4GHz), 125Hz (Bluetooth 5.0)
RGB color: 16 million
Backlight: Yes
Size: 130 x 95 x 18(front height) 23(back height)
Weight: 480g
Videos
Price Info
Price: 54.99 USD +
Purchase Now
Please feel free to ask us any questions about the keyboard below! :)
Welcome to join our Discord and follow our Instagram,TikTok, YouTube  for more discussion, latest update and questions! :)
« Last Edit: Wed, 16 April 2025, 21:15:57 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline john08099
  • Velocifire MK
  • * Moderator
Re: [In Stock] Stars 21 20% Programmable Aluminum Mechanical Keyboard
« Reply #1 on: Mon, 30 June 2025, 22:45:01 »
Check Out The New Review!
By WabiSabi
