Author Topic: [GB] Apostle - 65% designedbydark  (Read 2279 times)
Offline Lil
    • designedbydark
« on: Fri, 25 April 2025, 23:14:04 »
APOSTLE
Typing test forcebreak on v1 weights only:
Typing test (v2 weights) no forcebreak:
GB form: https://forms.gle/dTwprz5EAQFKAyc79
Link to Discord: https://discord.gg/4Cf5FTpFfu
Plate Design:
Design and intentions:
    • Balanced, proportional and subdued aesthetic, with dramatic reveal from behind
    • Unique weight design. My first 65% keyboard design!
    • Makes use of [larger] M4 screws for case fastening, tastefully embraces the aesthetic of larger bezels
    • Case walls are not too thin
Pricing and sale information:
    • 650USD before shipping (+50USD for titanium plate add-on)
    • Will involve participants paying the manufacturer (DDS) directly via Alibaba
    • GB open until last 10 slots are filled or early May
Lead time:
    • Within 3-6 months of paying the manufacturer (DDS/DADESIN)
    • Will ship directly from the manufacturer
Specs:
    • 65% layout keyboard, ‘seamless’ topcase configuration
    • Approx weight: 1.75kg when built
    • 7 degree typing angle
    • Very low ‘front height’/ relative profile on the desk
    • Plate uses bumpon/spring mount designedbydark
    • MX only, 7U only, ANSI only plate
Changes between prototype v1 and v2:
    • Screwing weights together to reduce unwanted vibrations between them and remove need for ‘forcebreak’ between weights && also ensure complete fit (without tiny minor visual variations in gaps) between weights
Included in the kit:
    • Topcase: 6063 ALU [anodised]
    • Bottomcase: 6063 ALU [anodised]
    • Plate: Steel [Sandblasted + Coated]
    • Weight 1: Copper [Sandblasted + Coated])
    • Weight 2: Copper [Sandblasted + Coated])
    • 3M bumpons: 6.4mm - SJ5382
    • M4 case screws
    • M3 weight screws
Not included:
    • PCB
    • Daughterboard
Compatible with:
    • fly daughterboard
    • WT65 PCB, seems to also work with zed65 although not intended
Space for updates:
  • 25th of April 2025: Posted GB Page
« Last Edit: Thu, 01 May 2025, 18:19:25 by Lil »
