Author Topic: Happy Hacking Professional 2 caps stuck on problem  (Read 4940 times)
Offline dac9
« on: Wed, 03 November 2010, 01:47:45 »
Hey guys,
i have a happy hacker pro 2. it is now set to caps on all the time and i dont know how i have done that.
i cant turn it off. any help would be great...
regards,
dac9
Offline Rajagra
« Reply #1 on: Wed, 03 November 2010, 04:10:36 »
You might have hit Fn-Tab by mistake.
Just do Fn-Tab again to turn CapsLock off.
Lost CapsLock operation might be due to Advanced Key Settings under Text Services and Input Languages.
The "To turn off CAPS LOCK" setting can be "Press the CAPS LOCK key" or "Press the SHIFT key".
Game is different if you aren't using Windows, obviously.
Offline dac9
« Reply #2 on: Wed, 03 November 2010, 04:37:42 »
Quote from: Rajagra;241991
spot on mate... thank-you so much
